Corvette twin turbo hood
Old 09-06-2001 | 09:42 AM
MSTNG KLR's Avatar
I am currently purchasing a twin turbo hood for my 87 Z28. I have been informed that the gm hood shocks would be to powerful for the fiberglass hood and could punch a hole through it, Is this true? Are there special shocks for a fiberglass hood?
Old 09-06-2001 | 10:05 AM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
never done it, but some around here suggest old hood shocks off a junkyard car work.
The ones too weak to hold a steel hood up.
John
Old 09-06-2001 | 10:15 AM
MSTNG KLR's Avatar
The only problem with that idea is that on some junkyard cars i know that sometimes both hood shocks are not at the same strength and hoods open up one side more powerful than the other side. My buddys Iroc does that.Finding weak shocks at the same weakness could be a task.
Old 09-06-2001 | 05:34 PM
Camaroman's Avatar
would it be possibe to take a hood prop rod from another car and use that instead?
Old 09-06-2001 | 07:57 PM
Blue_Meanie86SC's Avatar
yeah, either that or make some solid supports that can be put in place of the struts when the hood is up. I saw someone do it before, looked like a pipe with the ends mashed together and a hole drilled in them, but it was chromed. Otherwise a prop rod will work, I know a guy with an 83 bird who did that.
Old 09-06-2001 | 08:21 PM
RCR's Avatar
RCR
Car: '84 Fiero ('01 GA interior)
Engine: '96 4.0 Aurora
Transmission: '96 4T80E
I'm using newer struts on my ASCD hood (3 or 4 years old). The hood still comes down if the struts are cold. I use an old adjustable shower curtain rod to hold it up when I'm in the garage. It's springy and has rubber ends on it.
Old 09-07-2001 | 08:43 AM
MSTNG KLR's Avatar
I have a pole to hold up my hood but i dont think at shows and stuff that it would be very attractive.
Hotrodboba400
12-10-2019 08:07 PM
86Firebird86
12-26-2015 08:21 AM
Drone358
12-10-2015 09:16 PM
Hotrodboba400
09-02-2015 08:28 PM
SlowAZ28
09-02-2015 06:19 AM
