Need to know where to get parts for windows
My windows rattle and I need to know where to get a kit so I can completly rebuild both windows. I dont know for sure what I need inside the door, but the rubber piece that goes where you rest your arm is gone.
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
You're talking about the inner windlace,, unfortunatly, the only place I've found is the dealer, the windlace (seal,w-strip, whatever you want to call it) comes preattached to the black plastic railing for about $130 for the pair from the dealer.
The other part that wears out is the little felt things under that black plastic. The inner & outer windlace both have this same felt but the pieces, mounted to the door sheel itself, on the inside hold the glass while it is down. I'm not to sure of where to get those parts,, there are no part #'s stamped on mine
As you can see, it's not listed on the collision diagram either. #5 is the w/strip part #'s you are wanting,, you might check www.gmpartsdirect.com for a better price than $130.
The mind is like a parachute, it only works when its open
LT1Formula
20
11-14-2015 12:02 AM
