what do i do about rust???
if there is rust on the body what do i do? cuz out a chunk and weld in a new one? or waht rplace the entire piece??? i dunno what to do!!!
89 IROC-Z 5.7L
bone stock for now...
89 IROC-Z 5.7L
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
If it is only surface rust, take what rust you can off by mean of sanding or wire wheel/brush. Treat the fresh metal to some cold galvanizing compund (available at a welders supply store for around 6-8$ a can) or as others would suggest, use some Por-15. I'd prefer cold galv but, I'm bias for having usedit on commercial outdoor bulding products for the past 5½ years (plus the gas tank is galvanized metal & look how long it's lasted).
The mind is like a parachute, it only works when its open
[MN] S&W 8 point rollcage
FueledSoul
09-30-2015 09:18 PM
tcflint
09-27-2015 05:58 PM
