Wierd Body Question/Pic Request
Ok, I have the chance to get a 1989 V6 Firebird for really cheap as a daily driver for while Im doing the motor swap on my Trans Am.
The Firebird has a damaged front clip, and there is a 82 Berlinetta in the junkyard here with a perfect front end. I can get it for REALLY cheap, and honestly, Im not planning on putting alot of money into this thing. I just want to get from Point A to Point B.
Does anyone know if the front clip i.e Fenders, and front end will just bolt right up? And, also, does anyone have any pics of a Firebird with a Camaro front end? I can kinda picture it in my mind, sorta!
-Roshambo
-Joe
1988 Pontiac Trans Am WS6 - 305 TPI, 700R4, 3.23 Posi, Digital Dash, Leather Seats, Maui Blue with Silver GFX, T-tops, Tinted Glass, Gutted MAF, TB Coolant Bypass, K&N Cone Filter, Hi Flo Cat, 3" exhaust from Y-pipe back, MSD Super Coil, Accel 8mm wires, L98 Aluminum Heads, Ported and Polished Plenum, Siamesed Intake, Aluminum Driveshaft, Edelbrock 3 point Strut Tower Brace.
[This message has been edited by Roshambo (edited August 30, 2001).]
-Roshambo
-Joe
Car: 1989 IROC-Z
Engine: 383 stroker
Axle/Gears: Moser 9", 4.11:1
But then what about the headlights? Firebird lights pop up, Camaro ones don't. I don't know if it would work if you swapped the fenders, front clip, headlights, and hood.. Might look interesting though.
1992 Camaro RS
5.0L TBI
Custom white-faced gauges
K&N Airfilter and ready to take on the world!
My 1992 RS
1992 Camaro RS
5.0L TBI
My 1992 RS
I have seen a few camaro-birds in my area. evereything bolts up just fine they kinda funny with the firebird tail light and camaro headlights. I'll go looking to see if i can find one and take a pic.
91 Z-28 Coupe
L-98, 700-r4
Borla cat back
Performance Resource chip
Centerline wheels
K&N, Gutted air boxes
Gutted cats
Best Pass = 13.710 @100
Best 60' = 1.842
on M/T Sportsman Pros
"I bought my car to get me girls, I'm still waiting"
91 Z-28 Coupe
L-98, 700-r4
Borla cat back
Centerline wheels
Gutted cats
Best 60' = 1.842
<font face="Verdana, Arial" size="2">Originally posted by MetalliCamaroRS:
</font>
</font>
I would think it would bolt up without problems since underneath the body panels its all the same.
I forgot to mention, the car is Maui Blue also. How cool would it be to have 2 Maui Blue birds?
-Roshambo
Location: Doghouse ······································ Car: 1989 Formula 350 Vert Engine: 350 L98 Transmission: 700R4 Axle/Gears: B&W 3.27
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
I have taken apart both, and from what I can tell, they are identical. The only diffs are the fenders, facia, headlights, the obvious stuff.
But be warned, the Camaro stuff is more difficult to work on, they had screws in really strange places. Firebird parts were so obvious.
Just my experience.
87 Formula Yellow/Black
5.1 TPI Automatic
Baer 12" brakes 4 wheels, KYB AGX Adjustable Shocks & struts, Custom Leather interior, WAAAY TOO MANY MODS TO LIST
87 Formula TPI (5 Speed) Yellow/Gray STOCK
1967 Buick Riviera 430hp Turns high 14's (Not bad for 4300 lbs)
83 Camaro (Parts)
83 T/A (parts)
http://www.3rdgenformula.com
Just my experience.
5.1 TPI Automatic
83 Camaro (Parts)
83 T/A (parts)
<font face="Verdana, Arial" size="2">Originally posted by okfoz:
I have taken apart both, and from what I can tell, they are identical. The only diffs are the fenders, facia, headlights, the obvious stuff.</font>
-Roshambo
The ONLY thing that your firebird would not have that the camaro has is the extra set of (high beam) headlights.
You might want to try and get some of the headlight wire connectors off the donor car for the headlights, just so they work. Of course i think if you dont really care you can just plug in the outer headlights it should plug right in.
Hopefully YOUR car's frame is straight. Otherwise you might need to pull and adjsut your (sub) frame a little to have everything line up. You would have the same problems with a firebird or camaro front clip.
John
John
The ONLY thing that your firebird would not have that the camaro has is the extra set of (high beam) headlights.</font>
Anyone have any pics of a Franken-Bird?
-Roshambo
Hotrodboba400
12-10-2019 07:07 PM
tonys91rs
10-10-2015 03:31 PM
Kenwood
09-04-2015 05:50 PM
