Is there an adjustment on the automatic trunk pull down?
Car: 86 sports coupe-83 berlinetta
Engine: 5.0 in the sports coupe-350 in the berlinetta
Transmission: 700r4 in the sports coupe-turbo-350 with a 2500 stal in the berlinetta
I just got my trunk pull down working but every time i pop the trunk the lid raises and then lowers, is there some kind of adjustment?I didnt know wich board to put this on.
83 berlinetta currently 350/350 3:42 gear,2500 stal,3inch exhaust,2 1/4
exhaust manifolds,comp cam 268,performer intake
L69 dual snorkle aircleaner 3160lb
86 sports coupe lg4 2:73 posi disc brake 3 inch exhaust with some kind of flow master(Dual tail pipes)ugly primered Z28 or iroc front bumper.
replace the lifter rods if their bad it will go back down. If the steel loop makes deep contact with the machanism, the latch catches, that pushes a button inside, the button ques the pull down to turn on.
Thanks guys!
I agree with the "replacing the struts" suggestions. But yes there is an adjustment to the hatch pull-down unit. But most important, mark its current location with a permanent marker or scratch awl. Then loosen the 3 bolts holding it to the body (1/2" or 13mm wrench) and adjust, then tighten.
90 RS Convertible
Owner: Top-Down Solutions
(626)369-0040
http://www.sc3gfb.org/members/lonsal.html
http://www.taskerinc.com/gs3/profiles/Lon_profile.htm
90 RS Convertible
(626)369-0040
![](http://us.f1.yahoofs.com/users/eef0140b/bc/My+Photos/RS+thumb.jpg?bcirv07AYOGczvLs)
colton_carlson
03-08-2019 12:21 PM
