What the hell? Whats going on?
Location: First one out of liberty city, burn it to the ground
The little vents on the next to the driver and passenger legs, where does the air from there come from? Mine only blows hot *** air all the time! Where does it come from? Id like to see if i can do something about that hot air.. can the vents be turned off or something? I have a/c if it matters..
1989 Firebird. Modded.
My car is currently listed on ebay:
http://cgi.ebay.com/ebaymotors/aw-cgi/eBayISAPI.dll?ViewItem&item=594662251
"I'd rather run last in a full out race, than to NOT have run at all"
#3 Forever
#3 Forever
Car: 92 Z28 Z03
Transmission: 700-R4
Axle/Gears: 2.73 G80
im not sure on this and someone might want to correct me but i think the heat just comes from the engine or the tranny when they get hot. I really don't know what u can do about it.
86 Z28:
L98 350
aluminum heads
T-5
235/60R15 BFgoodriches
dual 3"flowmaster exhaust
20% tint
hatch wing
2 12"kicker solos
300 watt Sony xplod amp
Sony xplod deck
K&N air filter
http://www.geocities.com/xmikex.rm/mike.html
86 Z28:
L98 350
aluminum heads
T-5
20% tint
hatch wing
2 12"kicker solos
Sony xplod deck
K&N air filter
OMG Where am i?
wheres my pants....oh im old..... damn....
lol.... hmm... wow..... are you sure that **** on the heater control isnt set to on?
or perhaps it was one time, and then it broke the connection, and is staying on...
Hmm... "ItBurrrrnnnss!!!"
thats all igot....
91 FireBird 305 V-8
Edelbrock Catback, Custom Alarm. Fourth Gen Console. i have six cupholders. all for starbucks!
Go|)Created The Earth, And Then Turned Up The Bass.
Here's My Audio Install!
"Honda's FOR ME TO POOP ON!" -Triumph...
thats all igot....
91 FireBird 305 V-8
Nope.. its not on or broken.. im kinda confused on why its happening too..
700r4-->t5 w/ram clutch
Cold air, 1.6 rockers, 21lb injectors, 3" y-pipe, random tech cat, 3" ipipe, flowmaster 80 series 3" in 3" out hand made stainless tips, Lakewood LCA's, Msd 6a, Msd coil, Wonder Bar, 180* stat,
Coming Soon: T/a hood, Painted,Spohn Panhard Bar, 4thgen Front Seats, Cam!, Msd 8.5 wires, Posi (ACCEL IS CRAP)
See my car Here!
In Memory of #3 Dale Earnhardt
See my car Here!
I think you'll notice that the air coming from those vents is usually stronger when you don't have the AC or heating system turned on. I don't know exactly why, but if you turned the AC vents on or even the defroster, the air from those vents lessens.
You should also notice that if you change the temperature switch to cool (blue side, duh) it will blow cooler air through those vents.
See, on hot days even with the thing on cool its still hot *** air! Thats kinda whats annoying.
See my car Here!
See my car Here!
To check it out, turn on your a/c with the lever in the "bi-level" position. You should get cold air at those vents as well as the dash vents. If you get hot air, your
heater valve may be leaking internally.
Ok...will check that out..thanks for the tip.
See my car Here!
See my car Here!
it is designed to do that, it helps ventilate the engine compartment (as well as other functions I'd imagine). You should have some air moving at least. If you have AC it shouldn't be a problem, if not, put it on defrost with the windows down the hot air will go right out.
1986 Camaro Sport Coupe
Stock 305 cid. LG4 engine
3" catback dual exit exhaust
Metallic Indigo Blue Paint
Gloss Black Interior
L69 dual snorkle intake
dimented24x7
09-06-2015 03:51 PM
