Why does my car sit this way?
I decided to measure my car at all 4 wheels from the ground up to the fender. The passenger side of the car measure 28-1/8 inches at both wheels. The driver side measured 27.5 at the rear and a little less in the front. How come? The car has 168,000 miles...is that why?
How can it be fixed? Suspension problem? Is it doomed to stay this way? I just don't like for my car to look lop-sided.
89 GTA Trans Am L98
Wins: 2 Early 90s Stang GT, 4 wheeler, Chevy Malibu
Losses: New Camaro...bastard
1 Post
Car: 1984 Trans Am
Engine: GMPP 350 V8
Torque. I suspect that 160k of an L98's torque has twisted your car. I have no idea if it can be fixed. My fathers 71 Boss Mustang has the same problem.
83 T/A, 84 T/A, 94 T/A, 94 25th anniv T/A, & Some fords.
Location: Doghouse ······································ Car: 1989 Formula 350 Vert Engine: 350 L98 Transmission: 700R4 Axle/Gears: B&W 3.27
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
It could be a number of things, I noticed when I pulled my springs out of my formula that if you do not get them exactly in right then it would be lopsided. The reason for this is since you have Coil springs When they made the suspension there are indentations to where the ends of the coils are to go, if you twist the spring 180° then I would imagine it could change the ride height by 1/2" or more.
John
87 Formula Yellow/Black
5.1 TPI Automatic
Baer 12" brakes 4 wheels, KYB AGX Adjustable Shocks & struts, Custom Leather interior, WAAAY TOO MANY MODS TO LIST
87 Formula TPI (5 Speed) Yellow/Gray STOCK
1967 Buick Riviera 430hp Turns high 14's (Not bad for 4300 lbs)
83 Camaro (Parts)
83 T/A (parts)
http://www.3rdgenformula.com
John
5.1 TPI Automatic
83 Camaro (Parts)
83 T/A (parts)
Man, I have changed every thing on my car, yet it is still that way too. I was told it was the power of my awesome 305 . I have not put on my SFC's yet, but I quess it will still be lopsided.
Pics of my Car
http://photos.lycos.com/PhotoCShare/...7gc&AID=247820
305TBI, EDL strut tower brace w/spohn SFC's on the way and wonderbar, ASCD big block hood,
Eibach Sportline Springs,
Koni Struts and Shocks,
SSPE lower control arms and Panhard bar,
Hellwig Rear Swaybar and Energy Suspension bushings.Aluminum Driveshaft. Posi-rear
Pics of my Car
Car: 1987 GTA
Transmission: 4L60e
My car sat a little off in the front but was fine all the way around besides that. I got around to checking the pressure (even though all the tires looked to be proper pressure). My driver's side front was running right above 10psi
I reinflated all 4 after checking pressure and the car is perfectly even (even with the l98, my lead foot, and 130,000 miles.)
my .02
my .02
If it was torque...wouldn't the passenger side be lower? My driver side is lower.
New rear shocks...
Whoever had the car before me could have weighed a ton, but will never know.
I just figured if the unibody, or anything else was twisted from torque, the other side would be lower. I was considering rebuilding the suspension...and was hoping this would help my cars overall stance. But if the frame, or car isn't worth the effort, I won't bother.
Car: 1989 Pontiac GTA Hardtop.
Engine: ZZ4 - 350
Transmission: Garbage
I tend to agree that if it was torque, the passenger side would be lower.
Later
Mike
Check out My Car Pics http://albums.photo.epson.com/j/Albu...667&a=13599419
Gran Turismo Americano "The Ultimate Firebird"
Smokin 1989 GTA- Bone stock except for exhaust. (no catalytic-stainless pipe into Flowmaster 2 chamber) & AC Delco Rapid Fire Plugs
Later
Mike
