interior lights
interior lights
The interior lights on my 94 only turn on when i open the passenger door and not the driver side door. Whats up with that? All i can think if the wire is not on or something.
Chris
-94' firebird formula(I used to have a 91,thats why im on this site)
-All stock, but why change an already fast car in good condition.
Chris
HAHAHAHAHAHAHA, DUDE, reverse it and you got my car. Only drivers side lights up. Tell me when you figure it out bro!
un4givin89
1989 Camaro Ralley Sport, 305 TBI 5 Liter v8
Project List:
Crate 383 Engine
Flowmaster Exhaust
New Tires
Windows tinted
Interior swapped for two tone colors
Lowering Springs
Sound System
www.mikekey.net
un4givin89
Project List:
Crate 383 Engine
Flowmaster Exhaust
New Tires
Windows tinted
Lowering Springs
Sound System
www.mikekey.net
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
The door PIN switch (little button switch on the hinge pillar the door shuts against) probably isn't grounding properly.
The mind is like a parachute, it only works when its open
Location: Somewhere around the South Side of Chicago just crusin' in one of the Niteriders
Car: 92RS 25th Anniv./88 IROC Z28 Vert
Engine: 305 TBI w/Tpi Air / 305 TPI
Transmission: 700r4/700r4
Axle/Gears: Posi
Yeah, Replace the door pin switch. If your alarm is wired to go off when a door is opened this is probably not working on that door either because those are wired to the door pin switch. Cost about $10.. at GM dealer.
86 Camaro Black SS Coupe, T Tops, Flowmaster, Custom Paint, Dunlop Road Kings S/R tires, Wheel Country Directional Chrome Wheels,new charcoal & gray interior including seats and door panels, new carpet and headliner, complete front end suspension rebuild, new Valve seals, and more mods to come
'91 RS 5.0 TBI = Waiting to be modded, but has all of the toys inside.
http://www.angelfire.com/sports/niterider/86camaro.html
Morgan_Andre@hotmail.com
Car: '86 T/A
Engine: 350/LT1 Intake
Transmission: 700R4 - Built
Axle/Gears: 4th gen 3.42
Has anyone put "theater" lighting in their car? For instance, when you close the door, the light gradually fades away, instead of instantly shutting off? I am wondering how it can be done. It would be a nice finishing touch.
Third Gen Project
1989 305 tbi Camaro RS Red/Red
Ram Air II Hood
Centerline Champ 500 Rims
Edelbrock Open Element
MacEwen White Faced Guages
Third Gen Project
Ram Air II Hood
I had the exact problem but with the passenger side. One day when the laziness bug went away I decided to figure out what was wrong. The wire that connects to the switch was cut. So I just spliced it back together. Worked. On the passenger side there is one wire connecting to the switch. On the driver side there is two wires connecting to the switch. The white wire is the one you want to follow to look for breaks. If you can't see one then with pin pushed in hook a multimeter to the white wire and to a ground on the car and check the voltage. If the multi doesn't have a reading on it then you need to look closer for a break. If it does the replace the switch.
EDIT: Oops, just noticed you have a 94. Your wire colors might be different.
1989 Pontiac Trans Am
305 TPI
Auto
2.73 Rear
Stock
Planned Mods:
Cam
Ported Plenum
3.42 disc rear
Headers and Exhaust
[This message has been edited by MY 89 T/A (edited August 27, 2001).]
305 TPI
Auto
2.73 Rear
Stock
Planned Mods:
Cam
Ported Plenum
3.42 disc rear
Headers and Exhaust
ambainb
04-25-2016 09:21 PM
The_Phoenix
02-04-2016 07:10 AM
