Rust behind wheel well/rocker area
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
1 Post
Car: 89 IROC
Engine: LSX 6.0 370, TU2 Cam, Fast intake
Transmission: T56 w/ lots of goodies
Axle/Gears: 8.8, Posi, 4.10, 31 Spline
Re: Rust behind wheel well/rocker area
its pretty common for them to strt rotting there behind the inner liner in the bottom corner. the good thing is that its a easy patch to do
Car: 1992 Z28
Engine: 355
So would I just remove the affected area and weld a little sheet over it?
1 Post
Car: 89 IROC
I would cut or grind out the rust and maych it up with a piece of sheet metal not just patch over it as it will just get worse. The rust needs to be cut out
ambainb
04-25-2016 09:21 PM
LT1Formula
11-16-2015 01:13 PM
hectre13
09-08-2015 03:38 PM
