rust hole repair
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Re: rust hole repair
What's the rest of the door like? Spots like that on the outside of the door scare me...if the door is rotting on the underside too, I'd consider just replacing the whole door with a used one. Replacement door jamb stickers can be purchased from here if you do decide to go that route http://www.ecsvin.com/
Car: 1987 camaro sc
Engine: lg4 305
the hole in the floor pan pull up the carpet and just weld it up then if so desired grind it flush prime it and paint it. then put something to coat the bottom to prevent the paint from getting screwed up. the door looks like it may have had bondo put on it at one time so hard to tell
