STEEL OR RUBBER ?
STEEL OR RUBBER ?
Hello everyone im new to this forum and wana say this is Great ....access to a lot of good experiance jus a click away . My time has come to do my fuel pump in my 1988 iroc convertible , have read many post about the fuel hatch , or tank removal . i have no problem cutting the hatch ...the only thing stopping me is ....if the fuel lines at the entrance to the tank are steel , then the hassel of cutting and installing couplings....which my cause stress further down stream on the lines ,which in turn my result in taking the tank down anyways. i have a basic manual and it shows a picture of rubber lines to the entrance . Anyone ever seen this ? could some models have rubber or are they really all steel lines?..... THANKS
Car: 1987 Trans Am
Engine: LQ9/L92
Re: STEEL OR RUBBER ?
the sending unit is all steel line until you get to the front of the tank, where you have a foot or two of rubber between the sending unit and the body mounted fuel lines.
To mod the sending unit lines right, you need to either flare them or have threaded fittings installed; something that will take longer to do than dropping the tank. Just cutting the lines and putting in rubber could lead to them blowing off the feed line due to pressure.
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
1 Post
Car: '84 Z28
Engine: '02 LS1
Transmission: '02 T56
Axle/Gears: LS1 10-bolt 3.73 w/Auburn Pro
Personally, I think it is easier to drop the tank and do it right than it is to cut an access hatch, finish it properly, cut the lines, flare them, and seal the hatch back up to the car. It's just time consuming and too much of a hackjob for me.
3rdgenparts
05-21-2016 11:50 PM
darwinprice
17
10-11-2015 11:51 PM
skinny z
10-05-2015 06:23 PM
roysatikas
09-22-2015 08:15 PM
