Cowl scoop, on fiberglass hood.
I recently got my hands on an 82ish fiberglass hood and I would like to bolt on a cowl scoop just would like to know if this would fit. Im trying to make it functional by cutting the hood.
Im just concerned of the length, it is 56in long and i measured the hood and it measures about the same, but since the hood curves down i may have trouble.
Thanks for any help and/or suggestions.
Heres the link:
www.up22.com/scoopw1.htm#SC-109
91 Camaro LO3 RS 5-spd
Open air element, 16in Chrm IROC-Z wheels, dual 30in chrm exhaust tips, Z-28 wing,ACCEL 8mm wires w/cap n rotor, K&N filter, flowmaster, headers in near future. dual fans.
Heres the link:
Cutting the hood and grafting the cowl on isn't actually that hard, me and Camrs89 (at least i think thats his screenname for the board) did this for his car and it turned out great. I'll see if i can get ahold of him and have him post some more details and maybe some pictures. It looks just like a one piece hood now that its primered!
88 Camaro (not an RS, or an IROC, justa camaro.)
305TBI/700R4/2.73
14" Open Element and Flowmaster 80 seires
Next up: headers and gears
[This message has been edited by HrdRockA4305 (edited July 22, 2001).]
305TBI/700R4/2.73
Car: 91 Formula, 79 Trans Am, 72 LeMans
Engine: 305 TPI, 6.6, 350 Pontiac
Transmission: T5, 3 speed, TH350
alright, it was alot of work, kinda fun but i like this sort of stuff.
step 1
Buy Hardwood 2 inch cowl
step 2
cut hole where you want the hole. (I cut the whole area out)
Step 3
buy rivit gun and rivits. Make sure hood is aligned and drill holes into the hood where the rivits are going to be. I did one every 1/2 inch.
Step 4
put a THIN fiberglass filler
layer over the rivits. just enough to cover them. Then build up the edge around where the two hoods meet.
Step 5
SAND SAND SAND more filler SAND SAND SAND...
Step 6
glazing putty (fills pinholes)
Step 7
Primer and enjoy
hope this helps.
1991 Chevy truck 5.7 engine
Competition Cam 454 lift
305 Heads
Edelbrock Valve Springs
Holley Red Electric Fuel Pump
Eldelbrock Performer RPM Intake
Holley 750 Double Pumper
68 jets front 74 jets rear
Turbo 350 transmission
B&M shift kit
Custom drive shaft
3.73 Rear end
Flowmaster exhaust
No emissions or computer
Grant steering wheel
http://www.fbody.com/members/Camrs89/
step 1
step 2
Step 3
Step 4
Step 5
Step 6
Step 7
Primer and enjoy
hope this helps.
305 Heads
B&M shift kit
Custom drive shaft
3.73 Rear end
Flowmaster exhaust
91TTOPZ
Exterior Parts for Sale
09-20-2016 12:42 PM
