can i spray paint plastic panels?
You can you have to go to your local body shop supply company and get a special type of prep cleaner and speacial paint, but other than that there is nothing to it. I personally wouldn't recomment it because the plastic paint does have a tendency to chip very easiley
I have used the vinyl paint to paint both vinyl and hard plastic parts. As long as you clean the surface thoroughly and scuff it up real well with something like cleanser it will do OK. It does chip fairly easily. As far as seat fabric and carpet FORGET IT. The vinyl paint says it works, but it doesn't. I have tried on both seat fabric and carpet and after multiple coats it still isn't right. The vinyl paint is expensive too so it is cheaper to get new seat covers and carpet than to try to change their color.
92 Convertible Z-28
92 Convertible Z-28
i had a post about this a few weeks back,. search my name, i had a lot of replys
Trent
---Car---
89 Firebird
305 L03 TBI A4
t-tops
---Stero---
Pioneer DEH-P730 Premium
Infinity 2way 4652 4x6's
Pioneer 4way ts-a6985 6x9's
profile cl640 110x4
2 pioneer 12" ts-w303c subs (selling if anyone wants em email me)
Future:im profile 1200sx 900watt x 1, and a pioneer cdx-p1270 12 disk cd changer
Trent
---Car---
89 Firebird
305 L03 TBI A4
t-tops
---Stero---
profile cl640 110x4
i painted all of my panels with "plasti-kote" vinyl and plastic paints and it worked really well. i cleaned them with alcohol and scuffed 'em up with some fine grit sand paper. i also found that if you prime the panels first that the paint wont chip
If you use a scuff pad insted of sand paper it will work a bit better. Sand paper won't get into the small groves, and it may flaten the surface. I have been told if you use some commet cleaner it works good with the scuff pad.
88 Camaro IROC-Z
350TPI
K&N filter , High flow exgaust (no cat's), automatic tran's shift kit
88 Camaro IROC-Z
350TPI
thats what i did. i used a pad and some comet on my interior pieces to be painted, and its held up for about 8 months fine with not a single chip off. i also put a spraypaint clear coat over the paint too. ill take a picture and post it in a little while of what i did.
Car: 83 berlinetta
Transmission: th 700
i have had most of my dash pianted now for 6 years & not one chip dont know what you guys are doing but i just treat it like any other body part degrease it with panel wipe nothing stronger primer with acrylic paint then acrylic topcoat & lacqer
I did the same thing you are planning on doing from grey to black.. it held up for about 6 months but now i am slowly replacing all the plastic pieces with black ones as i come across them since the paint is all chipping off.. It was a HUGE PITA and I regret doing it I should have just replaced the f*cking things instead of painting them because i'm replacing them all now anyways.
go to autozone and they make a paint adhesive in a spray can, its right next to the spray paint. i just saw it today. and about the carpet painting, yes they also sell spray paint for stuff like carpet and other fabrics (also at autozone)
1992 Trans Am
05-10-2023 08:19 PM
