Time to paint 1990 Iroc
Car: 1990 Iroc Z
Axle/Gears: 9 bolt
Body shop pulled it in today will keep you all updated on progress as much as possible.
Car: '89 RS, '89 Iroc
Engine: L03, LB9
Transmission: 700r4, T5
Axle/Gears: 2.73, 3.08
Re: Time to paint 1990 Iroc
definitely keep us posted, what part of maryland are you in and what shop are you using? if you dont mind
Car: 1990 Iroc Z
Axle/Gears: 9 bolt
Going with factory color. I don't know too much about paint work but I heard they do good work and that was my main concern. Hopefully they deliver. I thought the car deserved to be painted. I only paid 1200 for it with 79,000 on the clock. That freed up money for paint.
Car: 84 SC Camaro (92 Tribute)
Engine: V6
Transmission: M5
Well, the fact that they are completely disassembling it is a very good sign. It should look better than new when it's put back together.
Car: 85 Z28 T-Top 36mm sway & wonderbar
Engine: TPI L98 350 W/85 Vette Stage II ECM
Transmission: W/C T-5, alum drive shaft
Axle/Gears: 9 bolt posi, 3:27, PBR's, BB LS1's
Do you know about how long it will take them to finish?
Car: 1990 Iroc Z
Axle/Gears: 9 bolt
1 Post
Car: 1987 T/A WS6 T-Tops/92 RS
Engine: LB9/3.1
Transmission: 700R4/700R4
Axle/Gears: 2.73/3.23
Looks like they are doing it right, hope it turns out killer. Never tell a shop to rush, but never tell them to take their time LOL
Car: 1990 Iroc Z
Axle/Gears: 9 bolt
Car: 1990 Iroc Z
Axle/Gears: 9 bolt
Car: 85' Firebird (Project), 92' RS
Engine: 2.8L, LS1
Transmission: 700R4, 4L60E
Axle/Gears: 3.42 Open , 10 Bolt (ukn)
Looks like fun, i'll check back for updates. How much is this job setting you back?
Car: 1990 Iroc Z
Axle/Gears: 9 bolt
[quote=85f-bird;5536960]Looks like fun, i'll check back for updates. How much is this job setting you back?[/I don't have a total the shop is on the high side, but supposedly does good work. They are close to home easy to visit.
Car: 1990 Iroc Z
Axle/Gears: 9 bolt
Car: Red 1988 Iroc-Z hard top
Engine: 305 ( LSX swap soon )
Transmission: 700r4 ( T-56 swap soon )
Axle/Gears: What ever gear that come in 88 iroc
how much they charge to pain the car like that ? and your color code is bright red right ?
Car: 1990 Iroc Z
Axle/Gears: 9 bolt
#42
Car: 1990 Iroc Z
Axle/Gears: 9 bolt
Thanks, all pics above are before color sanding and polishing. They have been color sanding and buffing car for the last couple of days and it is really starting to look good. Car will be getting striped soon unless someone talks me out of it. I thought it would be best to put car back to its original form because it is so close and I have other non-original vehicles that are perfect candidates for modification. The only parts to be replaced during body work: all weatherstripping (gm), mirror gaskets, all emblems, parking lights, windshield and striping. Definitely could have gotten the job done cheaper but was looking for quality. Hopefully it pays off if not I'll know better next time.
#47
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Wow did they did a good job must have being a pricey paint job too though but worth those results!
#49
Car: 1990 Iroc Z
Axle/Gears: 9 bolt
