HELP, How Do I Remove the Headlight Knob??
Old 07-17-2001 | 06:14 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
HELP, How Do I Remove the Headlight ****??
I installed an aftermarket tach and the only thing I need left to connect is the light for it. I have the screws out for the panel by the headlights. How do I get the **** off so I can hook the wire up?
'86 IROC
T-TOPS, TINTED WINDOWS, BRAKE LIGHT BLACKOUTS
GM GOODWRENCH 350
EDELBROCK TES HEADERS
FLOWMASTER, NO CAT
EDELBROCK 600CFM CARB.
KN AIRFILTER
ACCEL HEI DISTRIBUTOR
160* Stat
2:73 GEARS
Rebuilt 700R4, with manual valve body
B&M Megashifter
Soon to be installed
3:73 Richmond Gears and 3" Hooker Aero Chamber
15.61@ 95.2mph G-Teched, need tranny work
"There is nothing more addicting than speed"
Old 07-17-2001 | 08:17 PM
jm91rs's Avatar
take off the underdash panel and look at the switch that the **** goes into. Take a long pencil (or anything that will not conduct electricity because it could easily blow a fuse) and on the switch assembly there will be a button with a spring on it. pull the **** out as far as possible and push the button in with the pencil (you may actually be able to get your finger on it to push it in) and pull the **** until it comes out. It is simple.
Jeremy
91 rs, convertible, K&N, Edelbrock open element cleaner, 3.73, B&M mega-shifter, goodmark cowl-induction hood,tinted windows,MacEwen Overlays
Coming soon...non red interior with 4th gen charcoal/grey seats
GeneralIesrussi
Carburetors
06-20-2024 08:21 PM
TheExaminer
09-07-2015 12:40 AM
andy74
09-03-2015 09:41 AM
RyanJB
09-02-2015 02:27 PM
IROCZDAVE (88-L98)
09-02-2015 09:43 AM
