spolier re-positioning
i had a coupl eof buddies siiting on the back of my camaro and the spoiler has moved back about 1/4 inch(just the middle part not the sides.....RPO D81 spoiler) can i just unbolt it and re adjust it or does it go deeper?
Car: 1986 IROC-Z
Engine: 5.0 TPI
If you open the hatch you can undo the 6 nuts holding it on. The middle 4 are covered by black plastic caps. Although its possible they cracked your spoiler where the bolts go in.
Good luck unbolting the spoiler. I took my old broken one off and every single bold came out of the fiberglass not the metal. Friend took his old one off yesterday and 2 did that. if you are keeping this spoiler spray some lube on before you undo it to avoid ruining a good spoiler.
GOFASTER
06-29-2001 02:07 PM
