Can you swap 91-92 door panels into a 88-90 GTA w/o modifications???
I was wondering,is it possible to swap door panels with the cup-holders from a 91-92 bird into an 88-90 Trans Am/GTA with little or no modification??? It looks like you can,just want to make sure
"A musclecar, by definition, is a powerful and sporty vehicle that must be able to spin its tires at will. The Firebird Trans Am is capable of laying down twin black streaks of rubber several hundred feet long. We wanted to be sure it could, so we did it a half dozen times in the name of automotive science."-MotorTrend
Transmission: auto
Sure it shouldn't be a problem. In my Bird I had the regular panels too, I switched to the GTa panels--the ones w/the built in armrests-I had to drill new holes in the rear plates for the handles-so if you're going from those you'll have to drill new holes-if it isn't those a direct bolt in.
Hope I didn't confuse you.
1992 Trans Am
05-10-2023 07:19 PM
IROCZDAVE (88-L98)
10-06-2016 09:08 AM
IROCZDAVE (88-L98)
08-06-2015 03:51 PM
