Door Panals
Old 07-07-2001 | 07:02 PM
CamaroLuvnPunk's Avatar
Door Panals
Where can I pick up new door panels for a non-ground effects car????
Erik
Old 07-07-2001 | 09:29 PM
Demon Z28's Avatar
Car: 2001 Camaro SS
Engine: Almighty LS1
Exterior or Interior?
Since you said non-groundeffects cars... I'm assuming exterior...
You can buy the door skins (the outermost panel on the door) for a few hundred bucks from Classic Industries, but you've got get the other one off and weld the new skin on...
They're the same for all F-Bodies, groundeffects or not... the groundeffects are bolted onto the underside of the door (I think, Don't take my word on that, it'll probably be corrected as I haven't looked in awhile)
But you might be better off getting another door from a pick a part or something and swapping the good stuff from your door over and have it painted to match...
Up to you though
Old 07-07-2001 | 10:02 PM
Blue502's Avatar
Like Demon said, the doors are the same whether with ground effects or without, Firebird or Camaro, only the ground effect doors have holes to mount the ground effects. Those holes can be welded up, but it would probably be cheaper to buy a good used one from the wrecking yard off a sport coupe without the gfx.
If you are talking about the interior door panels, then gfx have nothing to do with it. There is a standard interior and a custom (deluxe) interior, and both could be ordered on most models. These are different from each other with standard having vinyl panels and custom having cloth panels (at least on the Camaro).
Jorlain
Exterior Parts Wanted
06-30-2017 12:04 AM
Cam-aro
Camaros Wanted
11-12-2015 04:35 PM
86IROC112
10-09-2015 11:38 PM
oil pan 4
Fabrication
10-06-2015 12:56 PM
kkirch15
09-30-2015 05:44 PM
Quick Reply: Door Panals
