passenger door drags, help
Old 02-24-2013 | 04:13 AM
Sinfulrelations's Avatar
Car: 1992 Camaro RS
Engine: 305 V8
the passenger side door on my 92 rs drags on the bottom plastics when closing, it has no play in the pins, is there any way to fix this???
Old 02-24-2013 | 08:53 AM
W.E.G.'s Avatar
Car: 88 Sport Coupe Camaro
Engine: V6 2.8
Transmission: Borg-Warner T-5
Axle/Gears: RPO/GU6: 3.42
Re: passenger door drags, help
Has that side of the car previously suffered collision damage?
Is the alignment true beween of the top edge of the door and the body?
Exactly what part of your door is dragging?
Old 02-24-2013 | 11:15 AM
82tarecaro's Avatar
You sure there is no play? Did you try lifting the door when it is opened?
Old 02-24-2013 | 11:44 AM
dads old blue 9's Avatar
Car: 1990 z28
Engine: 5.0
Transmission: t-5 wc
Axle/Gears: 4th gen 3.42 posi
under the gfx is a strip welded to the car that the gfx mt to , with screws you can remove the gfx and bend the mt down about a 1/4 inch then re apply the gfx and all will be well .
Old 02-24-2013 | 02:53 PM
Car: 1992 Camaro RS
Engine: 305 V8
Size:  67.8 KB this is where it drags, no play in the door at all when wide open and it only hang up when the door is about 3/4 shut
Old 02-25-2013 | 12:13 AM
Blackdog36's Avatar
Car: 92 Z28
Engine: LS3
Transmission: TR6060
Axle/Gears: Strange S60 3.73
No play in the pins does not mean that the hinge pins are not loose/sagging. The stock hinge setups can sag a bit. When I replaced my hinge pins, I got them re-aligned by placing a folded piece of cardboard under the door against the door sill. This allowed the door to be up enough that when I tightened the hinge bolts, the door was at the correct level. The stock hinge bushing is not that durable and will allow for some wobble over time. You may not have much rubbing, but it is enough to cause issues. Just seems to be an issue with all of our cars since the doors are such a heavy one piece unit.
Old 02-25-2013 | 01:01 AM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
If indeed there is no play in the upper or lower hinge pins, then the hinges have bent due to the length of the door and all that weight. It is a very simlple fix using the EZ-Store door alignment tool I sell.
http://www.top-downsolutions.com/too...alignment-tool
Lon Salgren
Old 02-25-2013 | 07:32 AM
NCC-2569's Avatar
Car: 1990 Trans Am
Axle/Gears: Stock
So basically, this tool bends the hinges or pins using the leverage of the door?
No loosening of bolts or so?
Old 02-25-2013 | 10:29 AM
lonsal's Avatar
The tool bends the hinges back to their correct shape. It doesn't bend the pins. The cool thing is that the tool is very compact and easy to store and uses the breaker bar and socket you already own to provide the leverage needed.
You can't do this by using something like a floor jack because that would raise the enttire car. The door alignment tool uses the door striker bolt as the leverage point and latches into the door latch. Using the breaker bar you are able to raise or lower the door as needed to correct the alignment.
Lon
Old 02-25-2013 | 11:01 AM
tavert91's Avatar
Car: 91 Trans Am Convertible
Engine: LB9 5.0 TPI
Transmission: 5 SPD
Axle/Gears: Posi Rear
My driver's door was the same way. It had been sightly rubbing for years and then a few months ago, started to bind just where your's is and would no longer open using the outside door handle. I replaced both the top and bottom pins/bushings and then aligned the striker using Lon's tool. If you really think your pins are OK, just get the tool and see what happens. However, I think you will find the bushings are shot and are allowing the door to sag - it doesn't take much slop in the 20+ year old bushings to cause a problem.
Old 02-25-2013 | 11:23 AM
lonsal's Avatar
Correct. I tell my customers that you won't know for certain if you need the EZ-Store door alignment tool to correct the door alignment until AFTER you've done the door hinge repair.
Sometimes all it takes is the hinge repair kit to solve the problem. Other times it is the hinges themsellves that are bent causing the "sag and drag" condition.
Of course you'll save on S&H if you get the tool along with the hinge repair kit instead of S&H on two seaprate orders. It is such a small and cool tool (unlike the MAC Tools version I bought for my business before I started selling these) that it can be easily stored in a drawer or tool box until you need it. You'll also be a popular guy in your local car club. "Sure I can fix that, I've got the tool right here".
Lon
Old 02-25-2013 | 01:46 PM
NCC-2569's Avatar
Car: 1990 Trans Am
Axle/Gears: Stock
I'm gonna need new pants...
Never thought there'd be such a simple solution to such a common problem!
Thanks for letting me know about this.
tglennon11
09-23-2015 06:30 PM
billybob6110
09-23-2015 02:30 PM
tsfso59
Exterior Parts Wanted
09-09-2015 10:09 AM
Fronzizzle
09-08-2015 01:10 PM
NiG
09-08-2015 12:25 AM
