Door or Window Problem?
Old 06-15-2001 | 09:13 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Occasionally when I shut the door, the black filler and window itself are so high that they won't fit under the weather stripping. However, most of the time all works as it's supposed to. WTF? Any suggestions would be appreciated.
JamesC
Old 06-15-2001 | 04:12 PM
92Camaro305TBI's Avatar
Im not to sure what the filler is but i think mine does the same thing. At first when I closed my door and washed my car.. i noticed that air was coming out of the back side(not top) of the window... so i investigated.. took off the door panel.. Theres two peices(touching the window) that you can move back and forth(must unscrew first)... if you play with them you can get it just right to where theres no gap... However on mine, I moved them too far out and this pushes the window out... Causing the back of the window to have a gap big enought to see in the car. But if I shut the door with the window and not the handel... its a perfect fit.... Thats untill im driving 80 on the highway and the pressure sucks the window to have the gap.... really I think we need bigger windows... Hope this helps... BTW mine are hand cranked and not power.....
92 Camaro 305 TBI Automatic. Everything stock so far except a shift kit.
Future mods. Spark plug wires and plugs, tint, new 3inch pipes. Maybe putting 2 glass paks for effect. any other advise on getting to 300+ HP would be appreciated. Thanks
1992 Trans Am
05-10-2023 08:19 PM
Vintageracer
01-10-2020 06:33 PM
Out-Cast
08-23-2015 07:33 AM
evan555222
08-22-2015 08:14 PM
BlackTopKing
08-19-2015 01:13 PM
Quick Reply: Door or Window Problem?
