iroc/z28 ground effects on camaro LT
Car: 85 Trans Am WS6
Engine: 305HO L69
hi, i have an 87 camaro LT. i was thinking about getting some ground effects from an iroc and putting them on. i was wondering if the rocker/door effects, bumper cover, and front spoiler from an iroc would fit on the lt which did not come with ground effects. how hard is it to put them on?
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
you would have to change out the nose for one that accepts gfx (any IROC or Z from 85<?>-92)and the rest is lining up gfx & drilling out holes
The mind is like a parachute, it only works when its open
<font face="Verdana, Arial" size="2">Originally posted by deadbird:
you would have to change out the nose for one that accepts gfx (any IROC or Z from 85<?>-92)and the rest is lining up gfx & drilling out holes</font>
'86 Camaro Sport Coupe
Engine: 305HO L69
by changing the nose, does that mean i have to replace the whole front end, including the headlight bays? other than drilling the holes for the rocker/door effects, do any other modifications need to be done?
The rocker pieces bolt to a bracket that's welded to the rocker panels, so you'll need to attach that as well. Beyond that, it's just drilling holes and replacing the front and rear bumper covers.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
The IROC Homepage
Thomas
Exterior Parts for Sale
21
10-07-2015 05:33 PM
Thomas
10-03-2015 05:34 PM
92firebirdchris
08-14-2015 11:56 AM
