Gauge Question
Car: 1992 Camaro Z28 Convertible Z03
Engine: 383 SuperRam
Gauge Question
If I remove my gauges to scan to make white faces, when I take the needle off do I just put it back on at the position I took it off, or does it screw something up. I cant start my engine cause its blow (the reason I have the time to do this)...should I just turn the key and put the needle with those values. just dont wanna screw it up.
thanx
1986 Trans Am, T-Top, 305 TPI, Flowmaster 80 series. Much more to come in July.
[*]Sound System: Dual 12" Ground Zero Nuclear Series 900 watt RMS subs in custom box made to fit the rear well, Only 500 watts running them though, Pioneer Head Unit and Rockford Fosgate wiring.
AOL screen name= madbiker1
thanx
You have a small problem, then...it's nearly impossible to get anything besides the speedo and tach on properly without the car running. You should still be able to get guage readings, however, even without engine running. Don't worry about tach and RPM, you can do those with no problem. The fuel, temp, and voltage should still move when you put the key in "on" position. I don't really worry about my oil pressure, anyhow.
Ghettobird52
07-05-2024 11:18 PM
