Fuel press. guage install...
Old 06-11-2001 | 08:26 AM
gregz28's Avatar
I checked the archive and didnt find anything specific on this. Does anyone know of any tech. articles on installing the auto-meter A-pillar fuel press gauge? Which is ideal, electical or mechanical? Where through the firewall should the line be installed? Anyone have some advice?
91 Z28 305 TPI
Plans for 383...
Jet-coated TES headers, Flowmaster cat-back,
SLP cam, Cloyes double roller timing chain, TPIS shocks/struts, TPIS STB, adj. fuel press. regulator, 170 stat, B&M shift kit, BMR 1.5" springs, Fastchip custom chip, gutted air box/ ram air from fog light intake, 1LE rear w/ 3.23 gears, 2" cowl hood, Hurst dual gate shifter, Mac Ewen white face overlays
150 MPH without law
enforcement on your
A$$? Welcome to Europe.
3rdgeners in Europe: Join us...
fbodyeurope.com
generation3rdgen
[This message has been edited by gregz28 (edited June 11, 2001).]
Old 06-12-2001 | 12:23 AM
ScreaminDeamin85Z's Avatar
i just did this last week. i used a electrical Nordskog gauge w/ sender that i got out from Summit. there was already a hole in my firewall behind my pedals so i used that one, the guage is $40 and the sender is $40. i dont think that you want to mount a mech. fuel gauge inside your car. at least i wouldn't. the wiring is pretty self explanatory, considering mine had instructions . any more ?'s
Brandon
"ScreaminDeamin 360"
350 60 over, TRW forged 9.83:1 pistons,Hooker Comp headers, crane cam 216/228 .484/.512, crane 1.6 RR's, ported plenum, home made ram air, 24lb SVO injectors, crane AFPR, all going through 3 inch mandrel pipe and a flowmaster.
New project-89 IROC-Jamex Springs...and thats just about it till summer!
Soon- 6 speed, Pro 5.0 shifter and 4.10's
http://users.argolink.net/bvana
http://ScreaminDeamin.cz28.com
Old 06-12-2001 | 10:11 AM
gregz28's Avatar
Cool. All that is needed is the sender and the gauge, then? No more questions, as long as it comes with instructions.
91 Z28 305 TPI
Plans for 383...
150 MPH without law
enforcement on your
fbodyeurope.com
generation3rdgen
Old 05-28-2002 | 01:05 PM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Reviving old post
My Norskog sender didn't come with instructions. I mounted it in the car so far.
My question is how do I do up the wiring?
The sender has ground and positive. The gauge has 4 wires. How do I hook this up correctly?
Old 05-28-2002 | 03:37 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
There is a mechanical one, made by Autometer. It uses an "isolator" line, which gets filled with a hydraulic fluid- I think brake fluid? Anyway, the setup connects as follows:
in-car-gauge to isolator line to engine compartment to isolator
isolator to fuel pressure tap
I heard a while ago that they were a pain, because you have to bleed the isolator line so it's 100% free of air- and that Autometer had no bleeder provision. But it would be a mechanical gauge, except you'd have brake fluid coming thru the firewall, not gasoline.
Electrical would be much easier to set up.
Old 05-28-2002 | 04:33 PM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
For most intents and purposes the electric should be fine. Been told the mechanical are more accurate, but I do not know why that would be...
John
Old 05-28-2002 | 05:03 PM
89formula#1's Avatar
Car: 89 Formula
Engine: Carbed 5.7
Transmission: TKO-600
do u need a computer to run electrical guages?? cause i am goin to carb and i won't have one so i got an underhood guage for now
Old 05-28-2002 | 05:14 PM
82resto's Avatar
There's no advantage to mechanical except that it's usually cheaper. I have an electric one, and it's a simple install (autometer) You just run the wires from the gauge to black box they give you that you install in the engine compartment. Then you run the line from the schraeder valve to the box. Simple
Jon
Old 05-28-2002 | 05:21 PM
okfoz's Avatar
no, you should not need a computer to run electric gages, been running them for years. My 67 Riv has gages, and there is no computer.
John
Old 05-30-2002 | 12:02 PM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
But has anyone hooked up the nordskog electrical/digital gauge? I have the sender T'd into the fuel rail. Until I know how to wire it up it just sits there and looks pretty.
Old 06-05-2002 | 01:44 PM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Anyone?
I'm assuming I connect the black on the sender to ground and the red on the sender to the gauge.
Is this correct? I don't want to hook it up wrong cause I can't return electrical crap.
Nordskog doesn't seem to have a website so I can't ask them.
help
Old 06-05-2002 | 02:47 PM
Mongoose's Avatar
Car: 90 Formula
Axle/Gears: 9 bolt/3.27
I used their digital crap before and it never read accurately. Always jumped up and down even when a mechanical gauge was used to check pressure from the pump. I switched to the Autometer electric unit and the pressure is dead on and matched the mech test gauge exactly.
Old 06-07-2002 | 04:37 PM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
hmmm.
I hope mine doesn't do that.
How did you wire the sender?
Old 06-07-2002 | 06:40 PM
Mongoose's Avatar
Car: 90 Formula
Simply follow Autometer's instructions. I used a stud used to attach the small bracket underneath the steering column for the ground and a keyed on electrical source from the fuse block for the 12V. There should also be an extra source there to hook up the lights too. Make sure to use a test light. Running the wires and finding a place to mount the control module are the two hardest parts of the project. Took me all of three hours to do since I made a complete harness with weatherpack connectors in case I had to remove anything.
Ghettobird52
07-06-2024 12:18 AM
92camaroJoe
07-29-2023 08:57 PM
Glowsock
08-02-2020 08:36 PM
355sbcTPI
08-19-2015 05:38 PM
92camaroJoe
08-13-2015 07:07 AM
Quick Reply: Fuel press. guage install...
