SS hood Air Filter location
I have a big problem that maybe some one can help me with. I have a 92 Z-28 tpi with SuperRam w/1000cfm Accel throttle body, I also have the ASCD SS hood. I can not get the stock air cleaner set up to work my hood wont come all the way down with the stock setup so I put on a TPI cone filter on so I can use some form of filter but its breathing in all the hot air from the engine I guess making the engine get really hot while idling has anyone used this kind of setup if you did where is your Air filter if you had to do something custom I would like to see it post a pic or something. Or am I the only with this type of modification and having a problem. Any help would be great.
1992 383 Z-28 w/SuperRam intake and ACCEL DFI, PA Racing K frame,SS hood,SS rims
go get the may 2001 issue of superchevy magazine there is a blue iroc with a setup similiar to what u are asking about. otherwise give me an e-mail and ill try to get u some pics
87 IROC-z 305 TPI 5spd Borg warner 9-bolt 3.45 posi 4 wheel disc,8.8 Accel wires , bosch platinum +4 plugs,gutted air box,TB coolant bypass ,polyurethane tranny and torque arm mounts, k&n oil filter,synthetic oil 10w30, futura GLS super sport tires 265/50/15 rear and 235/60/15 front mounted on 86 monte carlo SS rims ,
400 sbc and a 6 spd in the works
1992 Trans Am
05-10-2023 08:19 PM
