A few prep & paint questions.
1 Post
Car: 1987 T/A WS6 T-Tops/92 RS
Engine: LB9/3.1
Transmission: 700R4/700R4
Axle/Gears: 2.73/3.23
I'm going to paint my 92 RS urethane Hot Rod satin black, single stage 2 coats. My car is gloss black now and has had one respray from what I can see, there is some surface rust and dings that need to be removed and smoothed out as well as some light damage on the drivers door and fender. My rear bumper cover has a large crack in it so I got a used one that has a crappy yellow respray-some chips and alot of spider cracks. My front cover and GFX are in good shape, but the front cover has a few spots where the paint is chipped down to the urethane. The main quetsion is how picky to I need to be on the prep work, such as the spider cracks and such since the car will be satin black? I want the car to look good, but it's not going to be a show car, just a cool driver that has to live outside most of the time, but never driven in the winter. This is a budget project car. The body work I know more about, but it's the bumper covers that i'm kinda lost on, I have read alot on here, but not many are going stain black and I know stain does not show flaws as bad.
I have started to hand sand the rear cover since it's off the car, but have not hit it with the DA yet.
Re: A few prep & paint questions.
I would recomend against satin due to the facts that it is not buffable and will loose "luster" over time. But to each his own. You may do some research on "matte" clears. I would go gloss black.
This is how I would do the car. Dissasemble the car. If you choose to not do engine bay, leave it alone, at a minimum do underside of hood, hinges. Soda and media blast the all panels. The plastic parts will have to use soda blasting. Rust, dent, plastic repair. Mask, Epoxy prime, High build prime, 220 blocking. Remask, Reprime high build, 400 blocking. Remask, sealer (black for black), x# of basecoats, (x# of clear coats, if applicable). Color sand and buff for non-satin,non-flat colors.
Prep work is everything. Since its had a respray and rust issues, I would highly recomend taking all old materials off and start fresh. Follow my advice and you will have a show car.
1 Post
Car: 87 Iroc
Engine: 350tpi
Axle/Gears: 10 bolt, unsure of gears yet
Personally, I'd go ahead and sand the bumpers right down, take out the spider cracks completely. That much of it is more time than anything else.
1 Post
Engine: LB9/3.1
Thanks for getting back to me, I'm not looking for even close to a show car with this one, the car has to live outside under a cover, it's a v6 hard top, not really a car I want to do a crazy build on, just a driver and get the body stright. Yeah I'm torn as the car looks good in glass black, but at the same time I hate taking care of gloss black and I have wanted a satin black car for a long time.
The piont of my questions is I know what it takes to get a car show looking, been there done that, but was wanting to know how picky I would have to be just to have a nice lookng car in satin black as satin is alot more forgiving. This is kind of a budget build if you will.
do you think you could post a picture of the rust on your camaro so i know what im working with? i picked up a 91 rs tbi last sunday and im wondering if the rust is fixable, its almost through the first layer but not any comments on that let me know ?? and dark colors bring out flaws in cars light colors hide flaws just a little tip my grandpa told me, im painting my camaro pearl white or just all white
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
How about starting a thrread and post pics of your rust you are concerned about?
1 Post
Engine: LB9/3.1
There are no holes or even close to holes on my car, just some bubbles around the rear wheel well lips, a new small bubbles here and there and some surface rust under the rear of the door handles. The are some dings and dents as well. I'm going to do the best job I can as if I get sick of the stain black or I sell the car the satin would make a nice base for gloss black. The underside of my car is very clean, same with the door jams and under the hood. The car has been painted before. The car was stored in the winters so not sure why there is so much surface rust on it?
if i have rust somewhat to this extent on my fenders is it fixable with duraglass i dont want to use bondo just because it looks bad? any response would be appreciated
i know this isnt a third gen either i just dont have pics of my rs to show and this is the closest math of the rust i could find
1 Post
Engine: LB9/3.1
1Aauto
Sponsored Vendors
09-13-2017 12:58 PM
IROCZDAVE (88-L98)
Exterior Parts for Sale
09-06-2015 06:23 AM
