Ripped off my door handle
Car: 91 Camaro RS
Engine: 305 V8
Living is Michigan has shown me that I need to invest in some lock de-icer. I purchased a 91 Camaro RS 1 year ago. So this is my 1st winter with it.
Long story short, my passenger door handle from the outside has not worked since I bought the car, but I ripped the driver side door handle on the outside off. The clips on the handle piece itself snapped (not a big deal to get a new handle), but the piece that the handle goes onto that is still attached to the door is broken as well.
Is there a way to remove and replace this part? I can't seem to find a replacement piece. I may be looking it up incorrectly though. I would think pulling the door panel off may show some screws for it, but before I get too far into it I thought I'd ask.
I'll post some pictures in the morning when there is some light. Thanks!
Car: 1987 camaro sc
Engine: lg4 305
Re: Ripped off my door handle
the the piece the handle pivots on? if thats what you are talking about take off the door panel have the window in the up position if you look in the door you will see 2 10mm nuts take them off an undo the clip. a new door handle should come with it
Car: 89' camaro RS TTOP
Engine: 92 5.0tpi Bosch III, headers, msd
Transmission: 700r4 built. trans go. 2,300 stall
Axle/Gears: 3:73 posi ls disc brake conversion
Sounds like someone has a strong arm
Car: 91 Camaro RS
Engine: 305 V8
I'll post some pictures in the morning. Good to know that there are some nuts that come off and that a replacement handle should come with the piece I need.
Thanks for the replies.
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Since you'll be inside the door anyway, the following link might prove useful--especially post #19:
https://www.thirdgen.org/forums/body...servation.html
JamesC
JamesC
Car: 91 Camaro RS
Engine: 305 V8
Thanks JamesC, few posts lower than #19 actually told me how to solve my door freezing issue - Thanks for the link.
I have asked 6 places that sell the door handle and none of them say the piece that bolts to the door comes with the handle. I don't have time to pull it off until later to see if there is a part number. Does is have a specific name so I can look it up? Posting a picture of the broken piece I need.
Here is a link to it since it does not seem to be embedding correctly - < https://www.thirdgen.org/forums/memb...en-needed.html >
Car: 1988 pontiac trans am
Engine: None
Transmission: None
Axle/Gears: 10 Bolt
looks like you just need a new door handle
http://www.1aauto.com/1A/DoorHandleE...07/280523/1991
On Probation
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
The door handle replacement is all one piece.
You just broke the chrome piece off the rest of the assembly.
It is replaced as a whole unit.
Car: 91 Camaro RS
Engine: 305 V8
Awesome. For some reason all of the pictures I found didn't show the 2 studs.
Got it installed on Sunday and it works great. Thanks for the help everyone
IROCZDAVE (88-L98)
09-17-2015 05:46 PM
gta892000
09-16-2015 12:37 AM
