View Poll Results: What are your interests in fiberglass fenders?
Yes, stock style.
33.33%
Maybe, for the right price.
16.67%
Yes, modified; fender flares, vents, etc.
16.67%
No, not worth it.
33.33%
Voters: 24. You may not vote on this poll
Fiberglass Fender Interest
Old 01-31-2013, 02:47 PM
  #51
sugarsn10's Avatar
Car: 1986 Pontiac Trans Am
Engine: 383 SBC
Transmission: WC T-5
Re: Fiberglass Fender Interest
I have enough suspension books of my own that ALL say drop spindles don't mess with geometry and that's where I'm leaving it. Either way, we should just get back to the original subject of the thread, which I feel now is a little more about composite body parts in general as opposed to just fenders.
sugarsn10 is offline
Old 01-31-2013, 02:51 PM
  #52
Johnny Blaze's Avatar
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
what about scrub radius?
Johnny Blaze is offline
Old 01-31-2013, 02:56 PM
  #53
hellz_wings's Avatar
Car: 1986 Chevrolet Camaro IROC-Z28
Engine: TPI 310ci (LB9)
Transmission: Custom Rebuilt 700R4 - 2600 Stall
Axle/Gears: 10 bolt, 3.73 Eaton Limited-Slip
Doesn't change at all.. The centerline of the tire would have to move in or out for it to change positively or negatively, the spindles don't affect this.
hellz_wings is offline
Old 01-31-2013, 03:57 PM
  #54
bestracing's Avatar
Car: 86 T/A - 70 Z28/RS
Engine: Broke - 350
Transmission: 700R4 - M22
Axle/Gears: G80, 2.73 - ZQ9 G80 4.10
Originally Posted by hellz_wings
I have alot to list.. and I am a firm believer of 'every little bit counts':
2" cowl fiberglass hood
aluminum waterpump
smog/EGR deleted
edelbrock headers with smog tubing cut off
AC system deleted completely (installed non AC heater box as well)
aluminum accel TPI intake manifold, AS&M runners, ported plenum
9th injector and piping removed
mini starter
window washer pump/hose/bottle removed
MOMO racing steering wheel
UMI tubular a-arms
LS1 front brakes
removed spare+jack (and placed lighter optima red top in rear)
aluminum 3" driveshaft
aluminum rear drums
Delphi 670 lightweight steering box
Antenna delete
And then I have added tons of stuff like SFC, STB, welded on brackets, etc.. And all suspension is all tubular (except k-member) which I think is lighter but I'm not sure..
What I have left to do:
aluminum front crash bar (have just waiting to install)
aluminum heads (when 383 engine swap goes in)
Lexan ttops
4th gen seats with 3rd gen sliders (weight reduction if non power and non leather)
Tubular k-member
Aluminum hubs
dropped spindles
And I lost 20 pounds since November lol
I'm surprised you haven't pulled the interior and removed the insulation padding from under the carpet and around the back panels.
bestracing is offline
Old 01-31-2013, 04:09 PM
  #55
It has full interior.. I'm actually going to add hushmat (already purchased) all along the interior under the carpet and panels, but I will offset this with lighter weight seats and lighter weight carpet without the backing (the hushmat should add a good bit of weight down low and in the center of the car so it's not too too bad, and hopefully lighter seats and carpet will offset the added weight)
The car is a street car, that is very capable on the track, that's what I wanted, ofcourse that costs money and is difficult to find that middle point.
morrow
01-13-2024 12:29 PM
Hotrodboba400
12-10-2019 07:07 PM
AmpleUnicorn88
South West Region
12-11-2015 11:53 PM
SG91camaro
09-05-2015 10:27 PM
Hotrodboba400
09-02-2015 07:28 PM
Quick Reply: Fiberglass Fender Interest
