How hard is it to replace power antenna mast unit??
I have taken off the inner fender and wheel off before but do I have to cut anything to get to it??It is a 86 IROCZ,I would love any info please !!!!!!!!!!
86 IROC,canary yellow(originally black),fully loaded.305TPI WITH 700R4/SHIFT KIT,3:73 POSI REAR,4 WHEEL DISC BRAKES,T-TOPS,POWER LOCKS,POWER WINDOWS,TILT,CRUISE,SADDLE INTERIOR,POWER ANTENNAE,SPOILER OFF 87 IROC SO NO THIRD BRAKE LIGHT ON ROOF,16" BY 8" RIMS OFF 89 IROC,3"INCH EXHAUST WITH A 2 CHAMBER FLOWMASTER AND 3 1/2" BY 18" LONG CHROME TIPS,20% TINT ON SIDES,HATCH AND T-TOPS,GTS TAILLIGHT COVERS,AFTERMARKET FOG LIGHTS,PIONEER 180 WATT CD RECIEVER AND DETACHABLE FACEPLATE,WITH JENSON SPEAKERS ALL AROUND,TALKING RADAR DETECTOR"BACON ALERT"
....Long live the EIGHTIES!!!and my love for the IROCZ
Mike, not to difficult, just a little tricky. Once you get the antenna assembly out, you need to drill out the rivet holes. There is either 3 or four of them, cant remember. Then carefully remove the steel side clips that hold the to motor casing halfs together. Carefully pry open the to halfs. Unhook the nylon mast cable from the drum and pull the mast out. Reverse procedure to put new mast in. Tricky part is getting the cover back on properly. I think GM sells a replacement rivet kit, however I just used some small machine screws and nuts. Well worth th time.
Good Luck
Good Luck
92camaroJoe
08-13-2015 06:07 AM
