Help!
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
This may help out some
https://www.thirdgen.org/messgboard/...ML/001290.html
-Welders get better penetration
Just to be clear, you do have to remove the very back interior plastic piece, and the spare tire cover to access the plastic wing nuts holding the tail lights in. It is in deadbird's description, under the great pic. The three nuts per side, in the corners, are removed from the inside, but you can access the ones on the left through the little cargo door and the ones on the right, after you remove the spare tire cover and of course, the spare tire.
Hope this clears things up a little.
[This message has been edited by Nightcruzer (edited May 16, 2001).]
