How do I remove glue from a fiberglass hood?
Old 05-01-2001 | 08:54 PM
Confuzed1's Avatar
Car: 83Z28 HO
Transmission: G Force 5 speed
I've tried Goof-off, Methyl ethel keytone, and a bunch of other stuff. Will paint stripper hurt the glass? It's a stock hood, and I don't want to ruin it. When I peeled off my hood decals, all the glue stayed on, and this stuff is seriously sticky. Any suggestions apreciated.
BTW- I drove it around the block for the 1st time (after the rebuild), even though the interior is still apart - (rattled like a bus). I was VERY impressed with how it ran. I was a little concerned with the cam I selected, but it's working great with the computer! I am a little concerned with traction though.
-1983 L69 Camaro Z28 305 H.O. (Bored .030 over,Teflon oil seals,Melling oil pump,Hyperetic pistons,chrome-moly rings,2040 Crane compu-cam) T-tops, 3:73 Open rear, BW T-5, Rebuilt E4ME 4 Barrel, Duel Snorkle, Rhino Clutch, 2040 Compu-cam, LS1 valve springs, porting, PST front end kit with new springs, K&N Filter and runs great but ain't streetable yet!!....Future Mods: JUNK IT if this keeps up!!
Old 05-01-2001 | 10:44 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
VINYL ERASER 3 AND 1/2 INCH DIAMETER
You can remove all vinyl pinstriping, graphics, and adhesive residue without damaging the paint. Simply mount the eraser in your air drill (recommended speed is 3,500 to 4,000 rpm) and safely remove all the old body striping in minutes. Unlike chemicals and solvents commonly used for this job. The soft wheel is gentle to the finish. Not recommended for acrylic lacquer or plexi- glass.
You should be able to pick one of these up at a local paint supplier, eastwood co. sells them for $13
-Welders get better penetration
[This message has been edited by deadbird (edited May 01, 2001).]
Frozer!!!
01-19-2024 04:55 PM
Street Lethal
04-30-2019 12:14 PM
Black89TA
Exterior Parts for Sale
07-23-2016 10:42 AM
cougar20th
08-27-2015 08:04 AM
3rdgenparts
08-08-2015 07:09 PM
Quick Reply: How do I remove glue from a fiberglass hood?
