Best dash protectant /Interior cleaner
1 Post
Car: 92 Formula
Transmission: A4
Once I do get a new dashpad, I want to keep it from cracking like my current one. The previous owner didnt take care of it....
So what is the best conditioning product for vinyl(sp?)? and the hard black plastic?
Thanks...
http://kiztope.50megs.com
92 Rs 3.1/T-5
Its slowly but surely coming along....
AIM : Theonekiztope
ICQ: 8787542
Planetarion: 3GFB kiztope of kiztopia-Camera-92RS-A (33:6:14)
"If it can be better than it is, make it so!" Leon Calrinsky (00)
Thanks...
92 Rs 3.1/T-5
AIM : Theonekiztope
ICQ: 8787542
I like EagleOne tire dressing and protectant. Used it on my Camaro's dash since I bought it new in 1986, and it still looks new. Won't melt the grain like Armor-All, and doesn't leave a film on your glass. Also it isn't super shiny like some products, which causes glare.
melt the grain????
http://www.angelfire.com/indie/jeff
1992Pontiac Firebird.
305 TBI
Metallic green/grey
T-tops
Still researching to find kick *** 350 for it.
305 TBI
Metallic green/grey
T-tops
It used to be years and years ago that Armor-All was the only option for protectant. Many cars, my '63 Nova included, used it. What happens is over the course of years, the Armor-All melts away any leather graining that is on the vinyl, and leaves a smooth and glossy surface. It did it on my car, and its done it to a lot of friends cars as well.
1 Post
Car: 87 GTA
Armour-ALL is kind of an evil product. It is petroleum based, and if used too much it will eventually dry out the material it is applied to - it will cause cracking in dashes and tires over time.
I use a product called 303 Protectant. It is a littel harder to find, and more expensive that Amour-all, but it will not cause cracking and it leaves the same look as Armour-all. It is also fantastic at removing the have from Gel-coat fibreglass!
87 GTA 350 TPI, 700R4,
K & N, Accel cap/rotor/wires, SLP airfoil, ported plenum
By the way... I also recommend not using Armor-All instead of wax on your paint job.
A friend of mine bought a firstgen Camaro, oh 7 or 8 years ago so so, and it looked pretty good for an older paint job. So he decided to restore it, and had the paint stripped off and the car repainted. Within a few weeks his new paint started peeling off. That was when he found out that the previous owner had used Armor-All on the paint for many years.
So my friend tore the car apart and had the body shell dipped to remove the chemical. He painted the shell, and again after a short time the paint started peeling again. The Armor-All had actually soaked into the metal rendering the body into a piece of unusable scrap metal.
Car: 2001 Camaro Z28/1995 Camaro Z28
Engine: just a little 5.7(LS1-320/340 RW)
Transmission: SMOOOOOOTH T-56/Auto. . .
Axle/Gears: 3.42 and 2.73
You might even try using DOW Tub and Tile Cleaner foam for cleaning! ! !
Don't smell too bad...
Got this trick from MeanYellowZ
works good on alot of rubber surfaces too
Duffster (age 32)
BEAT DOWN HARD 88' Camaro Sport Coupe,
1978 Caprice Classic 305 motor havin'(WITH NO COMPUTER),Torker II intake, Edelbrock 1406,600cfm w/vacuum secondaries,Accel HEI Supercoil/Cap/Rotor Sparkin',84' POS 700R4 Tranny usin', 84' Z-28 Nose clip wearin',
84' Z-28 Hood covered,
AND THE TIRES:
245/60-16 Firehawk SS20 on Firbird rim(1-passenger rear),
235/55-15 BF Goodrich's on CompTA's on Z28 rims(2-on front),
235/60-16 Pirelli P600 w/a curb check or 3 also on Firebird rim(1-drivers rear),
REAR HATCH MASTER OF ALL!!!
DuffsterCamaro@HOME.COM
Owner of the Camaro 0 out of 10 Third-genners approve of, no longer part of the non-existent Iowa crew.
Duffster (age 32)
AND THE TIRES:
Vintageracer
09-24-2017 12:34 PM
