Changing gauge needle color for white face overlays
I read that it is best to change the color of the gauge needles when you get the white face overlays. I heard that you do it with some kind of alcohol marker. Can you buy one of these pretty much anywhere?? I want to change them to an orangish-redish color to match the autometer phantom needles. Who has done this and can it be done without taking the needles off?? Thanks.
Car: 13' ZL1/91' Z28/10' Audi A5
Engine: 6.2L SC/5.7L 350/2.0L Turbo Quattro
Transmission: M6/700R4
well i read something about this on a previous post, dont know which one or when but you can take some fine grit sandpaper and sand the bottom of the needles right on the gauge cluster without removing the needles. the post said that the color of the needle was on the bottom and that the sanding will remove the color and then you can apply the color you want with the marker pen.
if you want try to do a search for this topic. i believe i read this approximately 3-4 months ago, maybe sooner than that.
good luck.
SS 17x9.5 wheels,
HOTCHKIS 1"drop springs,
HOTCHKIS tower brace,
Bilstein struts and shocks,
K&N filters,
MSD 6A,
MSD 8.5mm Wires,
MSD Cap & Rotor,
Hypertech airfoil,
SLP intake runner (plennum not ported yet, soon)
High flow cats,
SPOHN panhard bar, lower control arms, and subframe connectors,
Baer front track system,
3" Flowmaster Exhaust System,
2100 Stall High Performance Torque Converter,
300 watt sound system,
and soon to come...ZZ4 crate motor...hopefully.
good luck.
SS 17x9.5 wheels,
K&N filters,
MSD 6A,
MSD 8.5mm Wires,
MSD Cap & Rotor,
Hypertech airfoil,
High flow cats,
see if you can find mike harvey, he did it to his bird and it looked great
91 rs, convertible, K&N, Edelbrock open element cleaner, 3.73, B&M mega-shifter, goodmark cowl-induction hood,tinted windows,MacEwen Overlays
Coming soon......"Custom" non-red material.
Yes, the needle is coated with orange. Be advised, I tried this with a special marker and when I turned the lights on at night, it would NOT illuminate.
The sanding sounds like it might work. I would remove the needles though.
Mikes look sweet, but they key is to REMOVE THE NEEDLES. If you do not remove them and paint the back side of them they will not light up like perviosly said... in fact from the looks of it only the back is coated orange. Mike painted his silver, so the paint doesn't even need to be transparant, just make sure to paint the back!
What is the easiest way to get the needles off? I ordered my white overlays and I want to get the marker before they get here. How did you make sure that you put the needles back in the same place? Sorry if I sound stupid but it would be my dumb luck to either break one of the needles off or have the damn thing move on me.
Jay
black 85 Z28, t-tops, 4bbl carb, flowmaster 80 series muffler w/ custom tips (hollowed out cat), edelbrock chrome air cleaner, Infinity 4" 2 way front speakers and Infinity 3 way 6x9s, Alpine CDA-7863 head unit. many more mods planned (holley carb 4160 and edelbrock performer intake coming very soon)
Jay's webpage
Jay
Jay's webpage
From what I read on the tech article about DIY White Face gauges you start your car and let it run for a while and note where all of your needles are pointing on each gauge. Then just pull the needles off carefully. When you are ready to replace them run the car again and you will know exactly where they go.
Thornburg
08-25-2015 01:46 AM
LT1Formula
08-20-2015 09:36 PM
