Popup headlight wiring
hey, i just got a 85 trans am, but the headlights wont go up or down. it has a camaro's wiring harness so i think ill be needing new wires and relays going from the switch to the acuators. Can anyone tell me completely what goes on between the switch and the acuators? where can i get each part? thanks
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 2001 Camaro Z28/1995 Camaro Z28
Engine: just a little 5.7(LS1-320/340 RW)
Transmission: SMOOOOOOTH T-56/Auto. . .
Axle/Gears: 3.42 and 2.73
99% chance the motors are bad...SORRY.
The easiest thing to do is jumper the power to the motors and see if they work.
If not,...hit up your local junk yard and grab FIERO motors AFTER testing them! ! !
they are reversed from the birds motors.
L->R and R->L...get the point?
Hope this helps
<marquee type="slide">
</marquee>
Duffster (age 31)
BEAT DOWN HARD 88' Camaro Sport Coupe,
1978 Caprice Classic 305 motor havin'(WITH NO COMPUTER),Torker II intake, Edelbrock 1406,600cfm w/vacuum secondaries,Accel HEI Supercoil/Cap/Rotor Sparkin',84' 700R4 Tranny usin', 84' Z-28 Nose clip wearin',
84' Z-28 Hood covered,
AND THE TIRES:
245/60-16 Firehawk SS20 on Firbird rim(1-passenger rear),
235/55-15 BF Goodrich's on CompTA's on Z28 rims(2-on front),
235/60-16 Pirelli P600 w/a curb check or 3 also on Firebird rim(1-drivers rear),
REAR HATCH MASTER OF ALL!!!
Duffster_Camaro@HOTMAIL.COM
Owner of the Camaro 0 out of 10 Third-genners approve of, no longer part of the non-existent Iowa crew.
Hope this helps
![](http://www.geocities.com/duffstercamaro/sig.jpg)
![](http://banners.wunderground.com/banner/gizmotimetempbig/US/WA/bremerton.gif)
Duffster (age 31)
AND THE TIRES:
Ghettobird52
07-05-2024 11:18 PM
