Convertable
Convertable
The Convertables were made from T-Top cars right... so therefore i could get my own covertable by buying a t-top camaro and performing the chop-top covertable method. Anyone know the prices on this. (I doubt I will do it, but i am just curious)
huh? could you explain a little better? convertibles were from the factory from 87-92. an outside company made them into convertibles prior to that, and assume they still do. someone else should be able to help you out a little better
Car: 2001 Camaro Z28/1995 Camaro Z28
Engine: just a little 5.7(LS1-320/340 RW)
Transmission: SMOOOOOOTH T-56/Auto. . .
Axle/Gears: 3.42 and 2.73
no...Convertibles are made from Convertible cars...the T-top cars use the bar for structural support and removing the T-top bar would result in SERIOUS sagging of the lower body, kinked doors if you manage to open them and shortly...a floorboard that reaches the ground...permanantly.
Subframe connectors might help you, but recommend avoiding the t-top cut method.
Car: 1989 Camaro convertible
I think the cars were t-top cars that were sent out to get converted. They add support in the front of the quarters, right behind the doors. They also add a steel beam on the outside, right behind the ground effect. Ir you could find a wrecked convertible, it could work, but to buy all the pieces, and put one together would be way to much $$$$$
All the parts that are special for the convertible, cost way to much. But imo it could be done.
89'Camaro Convertible,96'firebird wheels,79'Z28 hood scoop, Dark yellow green paint from Bonnevilles, tan Mr. Mikes leather interior,Macewen white face gauges.
Dreaming of a RamJet 350,
Open element
Jet fan switch
180 degree thermostat
2nd place is always the first loser!
[This message has been edited by 89rsvert (edited April 07, 2001).]
Open element
Jet fan switch
Car: Camaro Vert
Engine: 355 HSR
Transmission: A4
Axle/Gears: 3.73 S60
Yup convertables were made from t-tops cars.. If ya look at the RPO list it has the CC1 code along with the one fer a vert.
Kat
Kat
OK, so you want a convertible. Two ways to go about it. Cut off the top off your t-top car. Weld the doors shut. Enjoy it for the Summer. Come Winter, throw it away (by then the frame will be bent anyway). Better way, sell the t-top car and buy a convertible. Trust me, there are too many differences between the models and extra reinforcing that would need to be added. Many of these parts sell at a PREMIUM, because convertible guys need them for their own restorations and repairs and so few were created in the first place.
90 RS Convertible
http://www.sc3gfb.org/members/lonsal.html
http://www.taskerinc.com/gs3/profiles/Lon_profile.htm
90 RS Convertible
listen to AmorgetRS
we talked about it before and he knows where he is coming from
(I'm not brave enough to cut up my car, but I did just find a 'vert body{bare shell} for $300 canadain)
Thirdgen89GTA
11-26-2015 11:04 PM
TMZIrocZ350
10-07-2015 12:09 PM
