rusty t-top weatherstripping channels question?
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 91 & 88 GTA, 89 Formy, 89 bird
Engine: 3 - 350 TPI, 305 TBI
Transmission: All 700R4's
Axle/Gears: unknown
I have a 91 bird with t-tops.
I removed the weatherstripping, on the driver's side there seems to be a rust issue.
I would like to remove and replace the entire channel.
Has anyone done this before?
Does anyone know where i could get a replacement channel?
Any help would be appreciated.
Axle/Gears: unknown
Re: rusty t-top weatherstripping channels question?
My t-bar is fine.
it is the car itself:
![Name: 1021120840a.jpg
Size: 93.6 KB](https://www.thirdgen.org/forums/attachments/body/359792d1501359161-rusty-t-top-weatherstripping-1021120840a.jpg)
this is the driver side rear
![Name: 1021120836.jpg
Size: 78.7 KB](https://www.thirdgen.org/forums/attachments/body/359793d1501359161-rusty-t-top-weatherstripping-1021120836.jpg)
this is the front
![Name: 1021120840.jpg
Size: 86.9 KB](https://www.thirdgen.org/forums/attachments/body/359794d1501359161-rusty-t-top-weatherstripping-1021120840.jpg)
a closer picture.
This is my problem.
this is the front
a closer picture.
This is my problem.
Car: '91 Firebird
Here are some videos on YouTube of a guy making new channels from scratch.
There's about a dozen videos of the entire process from start to finish.
Car: 87 Iroc
Engine: Turbocharged 5.7 Pro-Fl-XT
Transmission: 700R4 for moment
Axle/Gears: 3.25 9 inch
Here is a thread I made showing the basics of the repair I did. https://www.thirdgen.org/forums/body...-top-seal.html Hope it helps!
Car: 89 IROC Z28
Engine: 357 TPI
Axle/Gears: 3.42 Posi
My T-bar and a 3" section of the channel was rusted. I was lucky to find a t-bar in near perfect condition at a junkyard. I had Maaco repair the rust and replace the T-bar for around $300. I couldn't afford to get it painted but at least I stopped the rust from becoming any worse until I could get it painted.
Axle/Gears: unknown
I had an 84 t/a that had some rust when i freshened it up.
Similar to what some of you had mentioned.
Eight or nine years later, a little rust popped up outside the seal.
Underneath the seal had been very busy.
The amount of repair to the affected areas of rust to the structure of the frame
made my ride uneconomical to repair. I disassembled and parted it out.
I DO NOT want to do that again. That was 'my' ride.
Right now, the channel is the only thing affected.
Just lookin for a more permanent repair.
Axle/Gears: unknown
Regardless of what route I decide to take, the rusty channel must go!
So, I drilled out the spot welds (enough to remove the channel) and the removed the driver's side front and rear channel.
I DID NOT expect to find what lied underneath!
here is a pic of the front driver's side.
you can see the track being bent up in the middle
![Name: 1027121556-1.jpg
Size: 150.7 KB](https://www.thirdgen.org/forums/attachments/body/359089d1501357771-rusty-t-top-weatherstripping-1027121556-1.jpg)
There was literally NO PRIMER or PAINT underneath that channel !!!
WHAT WAS GM THINKING !!!
even though the passenger side looks good, it is now getting removed.
I will try to be a bit more careful than the driver's side.
It could be used as a repair section for someone else, maybe.
As for me, I have found an entire roof section - rust free - in California.
This is now plan B
Plan A is to make my own, preferably out of stainless - and bolt/screw them in.
This is now plan B
Car: 82 Z28
Transmission: TH350 for now
I got some off of a donor car. Drilled out the spot welds on the old ones and welded in the donor ones.
1Aauto
Sponsored Vendors
08-24-2015 03:40 PM
