I have a door pin problem!
Location: Newark,NJ> Where street racing on I 78 RULES!
How is every one doing tonight?
I'm having a problem with my drivers door. The door drags on the spoiler at the bottom of the door sill when it is closed. When i lift the door up, there is a lot of play in the lower pin area. Also, the lower pin can be pushed almost all the way out by hand! If I were to change the lower pin & bushing would the problem be corrected? How hard is this job (do I need two people etc.)How much is the pin kit for one door?
any info on this topic will
be appreciated,
thanx
njdaewoo
406 sb
dart 200 heads(out the box)
144 B&M blower
373 gears
Edl headers
3in cat back Flowmaster exh.
270 comp cams
12.50s @ 115mph
on street tires
60ft time 2.30
www.njdaewoo@excite.com
New Project car
86TPI trans Am
All stock for now
be appreciated,
thanx
njdaewoo
406 sb
144 B&M blower
373 gears
Edl headers
270 comp cams
12.50s @ 115mph
on street tires
60ft time 2.30
New Project car
86TPI trans Am
All stock for now
Third Gen Resource has a kit that you can work with. I forgot just how much it is but its a place to start. If you search the message board arcives there is one for how to rehang the door.
http://www.paddockparts.com
$12.95
91 Z28 305 tpi
plans for 383
jet-coated TES headers
flowmaster cat-back
To be installed: SLP cam, TPIS shocks/struts, 170 stat, B&M shift kit, TPIS fuel press. regulator
http://www.fbodyeurope.cz28.com
$12.95
91 Z28 305 tpi
plans for 383
flowmaster cat-back
i looked on there, and i only see ones for $15.95, i have a 92, so it would be $7.95 a piece? id have to get two of them? and where can i get this tool that supposedly makes it hella easy ?
I think i am having the same problem. My door hangs real far and when opened I get alot of play with it. I was hoping it was just the pins but I took it to 5 body shops and was told I needed to replace the pins and the hinges at a cost of about $450 including paint.
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
I replaced them about a year ago, I bought a big kit from jcwhitney that had 10 of each kind of pin and a bunch of bushings. It was a "master kit" and has all kinds of pins for just about any GM, Ford or Chrysler hinge. It worked out well and now I have all these extras and the kit was about $40.
Car: 1986 IROC-Z
Engine: 5.0 TPI
I had a similar problem on my 89 Beretta. Driver's door would just drop down when you openned it. I just went to a junk yard, got another lower hinge- problem solved!
If the alignment is off, take the kick panel off, and there are 3 15mm bolts that the hinge attaches to the door with. You can always try loosening them and moving the door up, then tightening them back down. I tried this b/c I didn't have the $ for new hinges. It didn't totally fix the problem, but it helped a little bit (door ended up breaking the GFX in half before I found the hinge bolts).
Vman
1969 Camaro Sport Coupe
383, 700R4, leather, everything black but the lights
Previous owner of an 89 RS Camaro
2.8L V6, 700R4
Vman
2.8L V6, 700R4
i had the same problem, napa has the pin and bushing set for the door for around 6 dollors, just be careful with the spring in the door, its a trick to get back in
I just repaired my hinges this past weekend.
If your doors sagging and hitting the jam or ground effect your upper hinge is also shoot, The upper is around $60. Youre going to have remove the door, drill out the spot welds, lay the hinge in the EXACT pistion the old one was at and redrill usaully 2 holes. The lower pin kit wont do s--t with out a new upper, you cant rebuild it since GM rivets the 2 halfs toghter.
I got my door spring compressor from http://www.toolsource.com/ost/dept.a...urceid=900EM10 last year for about $20, don't remember exactly.
I searched for it before replying here, it didn't come up, so you would want to e-mail them about it, that's what I had to do.
I went to www.toolsource.com and found the door spring tools by searching for "door spring".
This is the GM Door SPring Tool $11.95
which is here: http://www.toolsource.com/ost/produc...J74979AMV3D0V8
How does this thing work? Do you jam it around the spring, sqweeze it to together, then pull the tool out with the spring inside? Could I make one of these?
![](http://www.toolsource.com/OstImages/prodimages/55279.jpg)
Car: 1986 Trans Am
Engine: 305 LB9 TPI
Transmission: 700-R4
lower door hinge pin kit is $5/per door at Autozone.Not including the bushing.
goto http://91rsramair.tripod.com/home/id4.html
shows you everything you need and no more.
Car: '86 T/A
Engine: 350/LT1 Intake
Transmission: 700R4 - Built
Axle/Gears: 4th gen 3.42
AndyZ28 has a very nice hinge bushing repair kit. Its a little more than $15 bucks though. Its prolly worth every penny.
http://andyz28.com/3rdGen/
1992 Trans Am
05-10-2023 07:19 PM
