My fuel tank is leaking!
Hi, I'm the new owner of a 1982 Pontiac Trans am that I imported to Greece from California few days ago. Yesterday I went to a gas station to fill up my car for the first time and when I returned back to my home I noticed that fuel was leaking from the gas tank. The gas tank is looking in great condition from outside and before my visit to the gas station (it had only 1/4 of gas left) it did not leaked...
Car: 1987 IROC-Z
Engine: TPIS II Supercharged w/Nitrous
Transmission: 700R4 Probuilt
Axle/Gears: 3:73 Richmond 12 Bolt
Re: My fuel tank is leaking!
Examine exactly where the leak is coming from.. Is it the tank, or the lines.. Dont attempt to fix, buy a new one..
Car: 1989 IROC-Z28
Engine: L98 - 350 TPI
Transmission: MD8 - 700R4
Axle/Gears: GH3/G80 - 2.77 POSI
Look around the straps. Mine was leaking there. It's an easy replacement as long as you can get parts in Greece.
Car: 1989 Camaro RS
Engine: 1990 - 5.7
Transmission: Tremec TKO
Axle/Gears: 9 Bolt - 3:45
Lots of people have/ had this issue. Myself included.
You'll have to remove the tank. It's not hard but not overly fun either. If the inside/ outside of the tank looks good, (you said that maybe around the straps) you can have the filler neck re-braised. Any rad shop can do it.
Correct me if I'm wrong guys but there is only one company that makes a new tank for this gen of a Camaro. I bought one and it didn't go well. Read my posts in this thread: https://www.thirdgen.org/forums/afte...-gas-tank.html
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
I had a tank repaired by a radiator shop once,apparently they need to be welded under water.
Car: 1989 IROC-Z28
What? Lol. Tank replacement is simple.
All parts you see here I got at autozone.
Remove the cat back, lower the rear end, remove straps and take out tank. Install new tank in reverse. I replaced pump and sending unit too. Only doing this once!
Transmission: A4
I know this was discussed many years ago but I dont remember if anyone was successful.. can a plastic tank be installed in these cars? Are the 4th gen using plastic tanks?
plastic LS1 tank will fit, that's what I have... you need to do a bit of wiring tho.
Also, I was never able to find a step by step guide for rear end removal, so I put together one in my build thread.
starts on post 219
https://www.thirdgen.org/forums/ltx-...wap-pic-5.html
starts on post 219
