Need some info on a TA hood w/the 2 small vents..
Car: 1990 Formula
Engine: treefitty
Transmission: stick
I smacked up my car this weekend.Icy bridge.Anyhow I'm gonna need a hood, fender and fascia.
What I wanna know if anyone has that hood with the 2 small "grates".I'm not sure what their actual name is.
Can these things be made into some sort of "Ram-air"?
Do they go completely through the hood or are they just for show?
Has anybody utilized them in any way?
Also I'm getting the 92-93 fascia so I imagine the part where the fog lights go can be used as a way to pick up cold air.
Thank you in advance for any help.
Mike
1990 Formula
Factory:TPI-305/Dual Cat/5 Speed,3.42 rear, Dealer:Aluminum Drive Shaft(230hp)
Mods:SLP air foil,K&N Filter, Accel:wires,coil cap,rotor.Hypertech Thermomaster chip,Stat,Fan switch,TES headers,Flowmaster 3" Cat-back exhaust,TB coolant bypass, Centerforce clutch (going).
Car: '89 TA
Engine: LB9
Transmission: M5
Stock the vents aren't functional at all, just for show. The only person so far that i've seen modify them is this guy steve. Here's his website:
http://members.nbci.com/scauffiel/index.htm
Hope the referal helps
- '89 Trans AM, 305 TPI, 5-spd
- '86 Firebird, 2.8, Auto
Car: 1986 Trans Am
I cut mine open, mainly for cooling. Ram air doesnt really take effect until 70mph or so.
1986 Black & Gold WS6
Trans AM...The Muscle Car Lives
...Its just not at home at the moment...
Nosaints Coolzone
Nosaints Coolzone
Car: 1990 Formula
Engine: treefitty
Transmission: stick
I couldnt get to either you site or that one. I guess it's webtv limmitations.
I know Ram-air is for higher speeds. I'm interested in cooling/cold air first, as well as any possible Ram-air effect.I was thinking of rigging up an air box, under the vents, like they have in Next Gen catalog even though I woulnt buy the airbox from them.
It should look interesting: 87 hood w/a Banshee nose on a 90 Formula.
junkcltr
08-02-2019 11:12 PM
9192camaro
16
02-03-2019 12:21 AM
Black89TA
Exterior Parts for Sale
07-23-2016 10:42 AM
sailtexas186548
02-29-2016 08:40 AM
