Is my steering wheel gonna fall off?
I've got about 2-3 inches of vertical play in it, and now it started making a creaking noise, like maybe it's rubbing against the plastic housing right by the ignition. I know the exact problem, it's because the bracket for the tilt control is loose, but I don't have a wheel puller available to me right now. Is there any way it will actually come off, or did GM design it a little better then that? Thanks ahead guys.
-Reno
'88 Firebird LB8
"Cerberus"
http://www.angelfire.com/il/Firebird28/index.html
-Reno
'88 Firebird LB8
"Cerberus"
check the tech articles, there is one on how to tighten up the tilt column..should help some.
87 IROC-z 305 TPI 5spd Borg warner 9-bolt 3.45 posi 4 wheel disc,8.8 Accel wires , bosch platinum +4 plugs,gutted air box,k&n oil filter,synthetic oil 10w30
There's a nut holding on the steering wheel, and a clip in case the nut works loose. That should give it enough grab on the splines that it won't "fall" off, even with a jerk on the wheel. But I'd take a look at it quick since you'd literally be holding your life in your hands.
backtothe80s
09-05-2015 12:39 AM
