83 Z28 front clip
83 Z28 front clip
I have an 83 Z28 with crossfire injection, I need a new front clip, hood, and drivers fender. I found a plain 83 front clip. Is the plain front clip the same as the Z28? I have the ground effects from the Z. thanks,
Tim
Tim
Car: 2001 Camaro SS
Engine: Almighty LS1
CrossFire hood will be impossible to find unless you're extremely lucky...
Front clip for the Z28 is a solid (non-slotted like SC or Berlinetta) with the lower ground effect... easiest way to tell is the slots
Fender you can use from any year, but to match the ground effects you'll need to drill new holes if its not from an 82-84
Other than that you should be set... good luck on finding the crossfire hood though
1 Post
Car: 82 T/A WS7
Engine: Pontiac 400
Transmission: Muncie 4-speed
dowtyt, Just to avoid confusion a "clip" is everything from the doors forward. If you were to ask for a clip from a junkyard they would cut the car at the windshield pillars and the floor across at about the shifter or sometimes right at the firewall. Hence the word "clip". What you need is a bumper cover or facia. Don't let that word cost you a ton of money or confusion about avalibility.
Kenney
82 Trans Am WS7 notchback
83 Trans Am WS6 T-tops
72 Vista Cruiser 455
90 Olds Trofeo
80 K-10 w/snow plow
Painter @ Chevy dealer
GM junkie
Kenney
90 Olds Trofeo
80 K-10 w/snow plow
GM junkie
1992rs/ss
05-19-2020 07:02 PM
ambainb
04-25-2016 09:21 PM
1992rs/ss
16
01-28-2016 09:58 PM
Mutillator
Exterior Parts for Sale
10-01-2015 06:05 PM
