Headlights won't go down
Check my website - I've got a page that I dedicated to this problem. Though before you do all of that work you may want to see if your headlight relay is bad and replace that first.
Steve
Steve's Trans Am Temple
Steve
Hey, Steve, what do think about MY problem: When I turn my lights on, they go up. When I turn them off, the doors stay up. Is that the relay, or is one of the motors shot or something? Thanks.
Old: 1989 Formula, 383", DFI, built 700R4, TFS heads, Mini-Ram, Vortech S-trim 15 psi, 3.70 gears
Best ET: 10.796 @ 125.8 mph
New: 1989 T/A, 400" CNC Bow-Tie Tall-Deck, Accel Pro-Ram, DFI, AFR heads, HRC T76 Turbo, NOS 150-hp dry kit, TH400 w/GV overdrive, 12-bolt w/3.70 gears, 8-pt. S&W rollbar, Spohn suspension, 18" wheels, Baer brakes
Best ET: Spring 2001
Employed at:
Hahn Racecraft
Accel EMIC/DFI Tuning
Turbosystems & Custom EFI
Member of Midwest F-Body Association www.mfba.org
Employed at:
Hahn Racecraft
<font face="Verdana, Arial" size="2">Originally posted by GMI FAST:
</font>
</font>
Steve
It's wierd, dude. The headlights ALWAYS go up, but never go down! They don't make any goofy noise, either. They work fine until I turn the damned things off. The headlights shut off, but they stay up. Dammit!
Employed at:
Hahn Racecraft
Employed at:
Hahn Racecraft
With my ride, the lights go up and they turn on and off fine, but they won't shut until I turn the car off...weird stuff there
1991 Firebird Formula
305 TPI
Auto
K&N Filter
Grant GT Steering Wheel
5% Rear tint
Pontiac Windshield Decal
No real mods yet!
Former owner of an 88 2.8 Firebird....RIP
305 TPI
Auto
K&N Filter
5% Rear tint
No real mods yet!
Check this out. Turn your headlights on. Now turn them off --BUT-- push firmly inward on the switch while you do.
Did they go back down? If they didn't try it a few more times. If they did, more than likely you have a bad switch, but this little trick (not really) will get you by.
89 Formula 305 TBI
160* stat, 200* fan switch, K&N, Headers, 3in Flowmaster (hollow cat) back, pullies, 1.6 full roller rockers, B&M trans cooler, home-made ram-air
3.73 Richmond gears and SLP Zexel Torsen Posi (waiting for install)
89 Formula 305 TBI
I have had a similar experience.
Every once and a while, the headlight assembly will not go completely down.
Solution: All I had to do is press the switch further and ereka! they go down. Simple.
West Coast Performance
1989 Formula 305 TBI
1 Post
Car: '88 Firebird Formula 350
Engine: Built 383 TPI
Transmission: Built 700r4
Axle/Gears: 9 bolt, 3.27:1 Posi
I bypassed all of that crap by installing a momentary on-off-on switch. Solved all of my problems. I also by passed the headlight switch and ran another switch. Soon, I'll be dumping all of the original switches, and run my own creation. I'll post pics when I'm done.
'82 Firebird, dead stock, 9 bolt disc rear, over 200,000 miles and still going strong, more to come...
http://www.spinfrenzy.com/stingerssx...easures.html#4
