Where can I get these parts? (not junkyard)
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Top moulding -
P/n #1021 9043 $85 from the dealer![](https://www.thirdgen.org/messgboard/eek.gif)
I don't think the plastic grilles are seperate from the dash pad (at least there's no part listing for them)
My Firebird
Your Car Here?
Part Diagrams
My Firebird
Your Car Here?
Part Diagrams
$60.59 from www.gmpartsdirect.com
You should probably get new weatherstripping because when you remove it there is a good chance of jacking it up. So with that in mind:
Rip out your weatherstripping. Remove the six screws holding the plate in. Clean out the rust and other crap that gathered underneath the plate. Use good sealant* and replace the metal plate with the six screws you removed in step two. Replace your weatherstripping.
*I wouldn't use silicon due to it's tendency to "shrink" over time.
Steve
Steve's Trans Am Temple
Steve
LT1Formula
20
11-14-2015 12:02 AM
