anyone know how to roll back an odometer on a 91-92 style cluster?
Car: 1991 Camaro RS
Engine: GMPP 350 HO w/TBI
Transmission: 700R-4
Axle/Gears: 10-bolt w/3.73s
i put my crate engine in at "115546" on the odometer last summer. i want to roll it back so that reads as zero, but i couldnt figure it out. is it possible? how do i do it?
i am never going to get rid of teh car, so its not like i am trying to cheat someone, (nor do i plan to). i just think it would be cool to know how many miles are on teh motor.
thanks
-brian
1991 Camaro RS - Ultra Blue Metallic, T-Tops
GM 350 HO Crate Engine - Vortec Heads, Edelbrock Performer Vortec Intake, Holley 670 CFM Throttle Body, Open Air Cleaner w/14"x3" K&N, SLP 1 3/4" Stainless Headers, Edelbrock Victor Series Water Pump, March Unerdrive Pulleys, MSD 6AL, Blaster Coil, 8.5mm Super Conductors, Cap and Rotor, Hypertech Fan Switch & Thermomaster Chip, AC Delco Rapidfires, 3" Cat Back, Flowmaster 40 Series Muffler
700R4 - 2,400 Stall Converter, Vette Servo, Shift Kit, B&M Super Cooler
GM 10 Bolt -coming soon Auburn Pro Series Differential, Richmond 3.73s
Brian's 1991 RS Central NY F-Body Association
Join the Third Generation F-Body TBI Web Ring
z28boy@twcny.rr.com IM name: Z28 Boy
thanks
-brian
Car: 1991 Camaro RS
well i took the whole cluster out, and i couldnt figure it out.
there was a thing that i could "twist" a little, but it wouldnt budge. i dont know if there was some kind of lock on it or somthing that i had to take off. i dunno, i didnt see any way to do it.
thanks though,
-brian
thanks though,
-brian
my advice is to just reset the trip odometer then yank off the reset with some pliers cause i never use that darn thing anyway. I think it would be kinda neat to have the original miles plus engine miles on it
Car: 86 Trans Am
Engine: 406
Transmission: TH350, 4200
Axle/Gears: Moser 9", 3.89
Doesn't your trip od wrap around after 999.9?
I thought that everyone's did.
[This message has been edited by Trevor Jacek (edited February 05, 2001).]
1 Post
Car: 91 Red Sled
I heard you were selling the z28? Is that so? You never even took it to the track with the new motor, what's up with that? Oh well. So now you're trying to turn back the miles, hmm... Why not just leave it alone and show the shopper that it's got a brand new 350 and that the miles are only body but everything on the car has been replaced :-)
I'm still pissed that you never took her to the track. How about I buy the 670cfm TB from you and you swap on the stock :-)
, Jon (91 RS too many mods to list), getting new engine in summer
Car: 1991 Camaro RS
hhhhhhhhhhhheeeeeeeeeeeeeeeeeellllllllllllllllllllllllllllllllllll no im not selling it!!!
who told you that? no way will i get rid of that thing...its my baby - my pride and joy.
just intereted in hearing how you heard that.
-brian
-brian
1 Post
Car: 91 Red Sled
https://www.thirdgen.org/messgboard/...ML/000731.html
Funny, I didn't think you would get rid of her.
If you want to do this you have to be patient. But most importants TAKE IT OUT! Do not be in a hurry and just roll it back with your screwdriver because you WILL break it. Take the entire speedo cluster out.
Next, take the piece that has the numbers out all the way. Its easier said than done depending on the year mechanical vs electric. The key is to align the numbers where you want them AND have all of the little stoppers come back into the little cut ou where they belong.
This probably makes no sense, but if you tear it all apart, you'll understand.
89 Formula 305 TBI
160* stat, 200* fan switch, K&N, Headers, 3in Flowmaster (hollow cat) back, pullies, 1.6 full roller rockers, B&M trans cooler, home-made ram-air
3.73 Richmond gears and SLP Zexel Torsen Posi (waiting for install)
89 Formula 305 TBI
Transmission: auto
Doesn't have to be that complicated--make sure you pull the trip od arm out first--you can tell who tried to do this because the clear lens is always cracked in the same place(look at the pic)Once you get the dash piece off pull the speedo out(pulls right out)then unscrew the trip od piece from the back--has small rollers in it--that's what really ads the resistance to the #'s--next just take a pwr screw driver to the last # on the mileage counter--it'll spin freely--and just go! #'s will spin really quick then!
Hope this info will be used the right way--not to cheat anybody! E-mail me if you don't understand.
Mutillator
Exterior Parts for Sale
10-01-2015 06:05 PM
