Water leak
Water leak
I'm finding my front driver side floor to be soaked with water and it's turning my carpet into mildew stained crap??? Where are common areas the water could be getting in from. I checked the firewall, windsheild, window floor. I can't find it. Maybee I'm overlooking the problem area but any advise would be appreciated.
1 Post
Car: Firebird SSA
Engine: 3.1
Any water on the passanger side ???
For some reason I'm thing of heater core...
90 Firebird SSA (Bone stock 3.1)
Everything Below I've added
Engine: Accel Super Coil, 8mm Accel Ignition Wires, 170 Degree Thermostat, NKG Plautum Plugs, K&N Filter, Flowmaster 80
Suspension: Bell Tech Drop Spindles, Edelbrock PanHard Bar, Lakewood Lower Control Arms, Wonderbar IROC-Z, KYB GR2 Struts, KYB Gas-a-Just Shocks, PST Suspension Polygrapite Bushings All Round, 36mm WS6 Front Sway Bar, 24mm WS6 Rear Sway Bar
Brakes: Cross Drilled and sloted Rotors
Appearance: Trans Am Tail Lights, Trans Am Wrap Around Wing, Trans Am 16" Alum rims, Tinted Windows Rear 90% Sides 50%
Interior: GTA power seats, Overhead console, Power windows, Power locks, T-tops, Sun shade, Pioneer P77DH, Uniden radar detector, Intellitronix - Fuel pressure gauge, Transmission temp gauge. (In pods)
Nope, no water on passenger side. I'm dreading the day that damn core decides to let loose on me. (Knock on wood). I'm am stumped on this one guys..........keep 'em coming though.
hmmm, only thing i can think of is leaky weatherstripping or a hole in the floorpan, but I doubt that one. maybe get someone to hose it down while you sit in it and check for leaks. That's about the only was I can think of findin the problem.
Car: 89 Formula / 09 G8
Engine: LS1 / LS3
Transmission: M6 / M6
Axle/Gears: 3:42 / 3:27
Do you have t-tops? They are notorious for leaking (trust me, i know) Check the weather stipping around the window. The door might need adjusting (move the pin inwards) I also stuffed the weather stipping with foam to seal it to the window better (it helped a lot) If you do have t's adjust the locking pin holders.
I hope that helps
I hope that helps
- 89 Formula 305 WS6
SFC's,
LCA's,
Air foil
Flowmaster cat back
Tranny Cooler
A/F Ratio Meter, Trans Temp (not a mod but it sure spurs interest) - 90 Eagle Talon 2.0
(winter beater)
Mods? HA! its a rice burner!
I have the same exact problem on my passenger side. Does it still get soaked even if the car sits overnight in the rain and doesn't move? I have t-tops and I'm told that's my problem although I can't see how with no visible trace of water anywhere. I just posted on the board for this problem. If I find out anything different I'll let you know.
I don't know for sure with a 3rd gen, but it's common on 1st gen cars to leak water in from th cowl area. There are drain holes in the cowl that get clogged with leaves or debris and water then builds up and drains into the car. Do 3rd gens have the same possible problem? It might be a place to start looking.
If the car sits during the rain and there is no visible sign that water came in around the ttop, I would say that it isn't the ttops but could possibly be the above mentioned problem.
87 IROC 350 TPI with less than 10k original miles
www.users.uswest.net/~smoyer/iroc.htm
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
It could be leaking in through the fresh-air vent above the drivers' feet....the pivot for the windshield wiper is directly above the vent, and if the 'tar' around the pivot is missing or cracked, water will drip in through the vent.
Pete
Pete's Place
HiOutput Tech Page
83 SC
203+k mile LG4/5-speed
14.935@94.14
Pete
Pete's Place
HiOutput Tech Page
83 SC
14.935@94.14
