Help me save the bird!
Car: 1991 Firebird
Engine: None at the moment
Transmission: None at the moment
These pics are the passenger side front where the floo meets the firewall. The exterior pic is right behind the tire where the fender meets the gfx. Am I wasting my time? I realy want to save this car! Getting a rust free car and swapping my good parts is not an option at the moment (I cant buy another car and have it sit in front of my house unless I want a divorce
![Frown](https://www.thirdgen.org/forums/images/smilies/frown.gif)
Car: 1991 Camaro RS
Engine: The Wicked six'ah
Axle/Gears: stock 3.08's
Re: Help me save the bird!
haha this is when you Figure out one of two things.
1. How Creative you are to make it work and look good.(whos going to see it? besides us since your going to keep us updated
haha
2. If you've got the money to have someone else do it and possibly do worse than you could've in the first place.
do you have a mig welder? Your going to need one and i always prefer argon/co2 75/25 mix, I am ignorant with Flux core. and i refuse to learn. haha Your going to need some sheet metal from a Hardware store.. Sheet metal usually has oil on it when you buy it whatever you do if your welding it, don't use brakleen or Carb cleaner, any brands. Don't do it.
![Smilie](https://www.thirdgen.org/forums/images/smilies/smile.gif)
Car: 1991 Firebird
I have a welder and I'm already set up with 75/25. I was hoping to avoid the cost of new floor pans, but I think I'm going to have to replace them. So much rust... I don't really have the tools to fab the sheet metal my self either. So glad this isn't my daily driver!
Car: 1991 Firebird
Not sure what you mean exactly. The frame rails under the floor are rusty. I'll know how bad when I cut some of the floor away tomorrow. I'll post pics.
Car: 87 Pontiac Trans Am
Engine: Lapouttre Racing 350
Transmission: Rebuilt 700r4 Mild shift kit
Axle/Gears: 10 bolt 3.23 posi w/disc brakes
Good luck on your project. No pun intended but im glad that there are people whos car looked worse then mine. I had alot of rust as well and I am still battling with it but have won the fight for the most part. I have two really bad spots behind the rear wheel in the the trunk area that I am going to get welded up this Friday. They are the worse spots on the car and I saved them for last lol.
Car: 1991 Camaro RS
yea in the rear wheel well, its a major support piece, they make replaceable ones set ya back $700 ea without shipping... Ive seen a few get quite soft, and this may play a roll in whether its worth fixing or parting. as i hate to say that... but hey rather be safe than sorry. http://www.rickscamaros.com/camaro-f...1982-1992.html
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 1992 Chevrolet Camaro Z28
Engine: 5.7 TPI
Transmission: 700R4 Overdrive Automatic
Axle/Gears: 3.23:1 Positraction
Weld sheet metal or replace floor pan but worth saving. You'll feel better inside when its done.
Car: 1991 Firebird
I'll locate them this morning (fingers crossed) It's going to be a couple months before I can afford (by afford I mean - before my wife will let me) floor pans but there is plenty of rust elsewhere to fix until then.
I'm going to do some serious rust searching today. I'll post pics so those of you with rusty cars won't feel so bad.
![lmao](https://www.thirdgen.org/forums/images/smilies/lmao.gif)
Car: 1991 Camaro RS
yea pictures are good. haha Dont be shy, take a hammer one handed of course, and hit the rusty stuff That way you know what you have and what you've got to work with....
Car: 1991 Firebird
Are these the rear frame rails? Whatever they are, they're not in bad shape. Definitely need to be cleaned up, but the entire underside of the car needs that.
Car: 1991 Camaro RS
Inside the yellow Lines.
![](http://desmond.imageshack.us/Himg853/scaled.php?server=853&filename=jfcr.jpg&res=landing)
I do not own the rights to this photo. The Photos source can be found here.
https://www.thirdgen.org/forums/body...ouve-ever.html
![your welcome](https://www.thirdgen.org/forums/images/smilies/welcome.gif)
Car: 1991 Firebird
Not at all what I was looking for. I'll take a look when I get home. thanks for the pic!
Posted from Thirdgen.org App for Android
Car: 1991 Firebird
Okay... The rear frame rails are in really good shape! The rear fender wells are shot. At this point, I'm going to need most of a donor car. Maybe I'll be better off trying to find a rust free(ish) car and scrap this one for parts. Hmm...
Car: 1991 Camaro RS
You can weld in steel for the fender wells. no biggie... theres threads and pics here somewhere im just not going to dig em up at 11pm hahaha I just wouldnt get too carried away with patching the frame rail.... but if its good your all set!! just needs a few minor patches
Car: 1984 Pontiac Firebird
Engine: none atm
Axle/Gears: 3:73 zexel torsen
If you're battling surface rust or you can grind off/sandblast off the rust I've been having good luck with Eastwoods Rust Encapsulator. I'm restoring an 84 Firebird with some surface rust all over the underside ( no rot though ) and what I've sprayed so far has stayed rust free vs what I originally sprayed with Rustoleum. Spots that have been sprayed with rustoleum have already started to bleed through a bit. Good luck!
Car: 1991 Firebird
I will be doing a lot of that as well. If I had 3 wishes, no rust would be one!
Engine: none atm
I picked up 5 or 6 cans off of ebay and even though its Eastwoods ebay store it's cheaper than on their website and it's free shipping too. Check it out.
http://www.ebay.com/itm/Eastwood-Rus...68f756&vxp=mtr
Car: 1991 Firebird
Car: 1991 Firebird
Looks like Im going to have to pull the dash so I can weld in a patch panel without burning it up. I am also tearing apart the front end to get rid of the rust and repaint. Any ideas for a sturdy dolly with casters so I can still move the car around?
Engine: none atm
If you plan to leave the wheels and tires on harbor freight or Northern tool have some beefy reasonably priced dollys with wheels
Car: 1991 Firebird
No wheels, I'll be removing everything that's not welded together. There's rust everywhere. I want to kill it before it get's as bad as the floor pans.
Engine: none atm
You can build your own then, pick up some heavy duty casters and build 4 dollys from 2x6's. Place those under the frame rails front and back you should be golden.
Car: 1991 Firebird
I was thinking exactly that. Just wasn't sure if 2x6's would be stout enough. This is off opic, bu what kind of power are you getting from your 400?
Engine: none atm
2x6 will work out just fine, the smaller the dolly the stronger it will be, I would think that if you made them 1.5ft x 1.5 or even 2ft x 2ft that would work out fine to support your car in 4 places. And at the moment I'm getting no power from my 400 because it's torn apart right now. I'm in the process of doing a full restoration on an 84 bird. Right now the engine is mostly torn apart but with the parts I'm looking at I would expect around 450hp. I'm not getting crazy but I'm going to put in a cam, aluminum heads, aluminum intake and most likely a 650 cfm carb.
Car: 88 iroc
Engine: 305 tpi
Transmission: unknown atm
Axle/Gears: unknown atm
Will, I'm goin to have to post pics of my iroc so you will feel better.. your ahead of me tho I gotta find a welder, learn to weld and buy parts. Anyone know a good divorce lawyer? Wife is goin to kill me when I bring home a welder....
Car: 1991 Firebird
I would love to see pics of your ride.
Car: 1991 Firebird
Car: 88 iroc
Engine: 305 tpi
I got a step son that's 5 next month lil girl that's 2 in Dec. And one due next month......
Car: 1991 Firebird
Car: 1991 Firebird
If I decide to go with new floor pans, what is the best way to remove the bracing from the existing floor?
Car: 1991 Firebird
I may be giving up on this bird. The junk yards around here want $400 for a full floor pan. I can get a new one for around $500. I'm sure I can find A (mostly) rust free roller for not much more than that. On the plus side, I have a ton of parts now and I didnt pay much for the car to begin with. Hmm... maybe it's time for a standard transmission? I guess there is an upside.
sometimes they will sell you the whole shell cheaper than the floors. junkyard around me choke you to death with labor charges. if all the rust you have is the fender spot and by the heater core thn i say fix it. i tried fixing my 85 and if i could do that you can fix yours because thats nothing compared to mine.
Car: 88 iroc
Engine: 305 tpi
I'd take a battery powered saw and chop it out my self if I was you
Car: 1991 Firebird
Car: 1991 Firebird
#43
Car: 1991 Firebird
#44
best bet is to take all the good parts off it. find a local fbody forum offer up and body panels for free and cut the rest of the car apart. my 85 is also too far gone but the memory and history of it is too great so i bought a clean 92 that i will be swapping/ modding to keep my 85s memory alive
#46
Car: 1991 Firebird
A friend of mine just told me about a salvage yard that will let me do the labor myself. I'll be calling them this morning to see about a floor pan.
I pulled the dash over the weekend. That is going to be a PITA to put back in. I see a 4th gen swap in my future.
#48
Car: 1991 Firebird
Originally Posted by tylercamaro
id ask how much the whole car is personally. floors are a big long time consuming job. once you start theres no turning back
