Window seals at speed.
Does anyone else notice that your windows get sucked out of their seals when you're traveling over 90? Mine get sucked so far out that I can almost poke a finger out of the car through the gap in the sill. Has anyone else had this happen to them?
Car: 85 Z28
Engine: 305 TPI (dead) -> building 355
Transmission: 27 spline 700R4 (another one died) -> T5 goin in next
they did that to me too. I wasn't going 90 MPH though. I was going about 70.
Later,
Jesse
85 Z28, 305 TPI A4
pretty stock with MSD and a few other toys
15.2@91mph
http://photos.yahoo.com/j_hougnon
Later,
Jesse
85 Z28, 305 TPI A4
15.2@91mph
typical camaro problem.. That's the reason camaro's are slightly more annoying when driving because of sound.. Many camaro books talk about the downside to the way the windows were made.. It's no big deal
Hey feel free to chat with me on AOL IM if you wanna.. Darkhal2000!
My site,
should <A HREF="http://www.demoncamaro.net
shouldbe" TARGET=_blank>www.demoncamaro.net
shouldbe</A> up shortly.
My site,
I don't Think so
My site, demoncamaro.net (add the WWW but this thing messes it up) Should be up soon.
Car: 90 IROC
Engine: 406
Transmission: GMPP 93/4L60
Axle/Gears: 9 bolt 3.27
The 2 gen F-bodys, and alot of other GM products have a little bracket that is under the weather striping. It hangs down below the top of the window when its closed just enough to keep the window against the weather striping. IM going to find one in a junkyard and adapt it to mine. It would be easy to install just run a self tapping screw under the weather striping to hold it on. Its rubber coated so not to scratch the glass.
I was reading a book on the GNs, and they were having problems with this. It was because this peice was broken or missing.
Black 90 IROC, L98, A4, 323 gear. SuperRamed 406 in the works!
Thats odd that you say that about the 2nd gen. I have a 77 Firebird and it is also noisy at high speeds. I wonder if that will fix the problem on the 3rdgen.
91 Z28 305 tpi
plans for 383
flowmaster cat-back
Ram air to K&N cone
91 Z28 305 tpi
plans for 383
flowmaster cat-back
Ram air to K&N cone
1Aauto
Sponsored Vendors
01-15-2016 06:26 AM
1Aauto
Sponsored Vendors
11-09-2015 02:25 PM
blackandblue02
09-10-2015 08:19 PM
