'88 Firebird aerowing hardware.
Car: '88 Firebird Formula 350
Engine: 350 (5.7 TPI)
Transmission: auto 700R4
Axle/Gears: BW 9-bolt L.S.
I need the clamp that attached the rearspoiler leftside arm to the hatch.
Anybody knows where to get one?
( a picture of a good one would be nice, mine is badly corroded, I'm not sure what it should look like...!)
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Re: '88 Firebird aerowing hardware.
Do you have a pic of the area your talking about.Not sure of what your asking.
No pic, but it's the part/clamp that hold the wing's side parts, pointing foreward, there are two, left and right, as far as I'm aware of, the left one is corroded at my car.
Engine: 5.0 EFI
would it be the part that holds these clips.
Engine: 5.0 EFI
Is that a fiberglass replacement spoiler??if not that hole your showing should not be there.
even if it's a fiberglass one, that hole shouldn't be there,Someone installed that incorrect.
You should have three clips on each side that the spoiler locks down on,one at the very tip,one in the middle and
one on the bottom,then you have two bolts that go through the hatch deck.
It's the original spoiler that came with the car in 1988....!( I own the car since 1993...)
There is no hole, ( I guess it's the black, mirror like paint that's confusing..??), but there is something rusting/growing inside that piece of the wing.
Btw, what are those plastic clips in your post above?
Where are they supposed to be?
Engine: 5.0 EFI
If you want to fix that spoiler,you will have to remove it from the car.First you remove the caps under the hatch deck,you will see bolts on both sides of the deck,remove them and push forward on the spoiler and those clips will come off with the spoiler.Then you can see what is wrong underneath.Those clips above go into a slot on the hatch under the spoiler,then the top of the clip goes into a slot that is in the spoiler.
Thanks, I'll give it a try!
(Is there a metal frame inside the spoiler?)
And are those clips still available do you think?
Engine: 5.0 EFI
Their is metal in the spoiler,but it's in the rear section part that lays on the deck,but those clips go into small separate metal pieces along the sides.I'm on my way over to the body shop,Ill take a pic of my old spoiler(having a new fiberglass one installed)I'll get pics of the bottom to show you what's under there.And those clips in the pic are for sale,they are a SOB to find.The new spoiler doesn't use those clips.See you in a bit.
Engine: 5.0 EFI
Hers what your spoiler looks like underneath
Their is 3 slots on each side with a metal piece,the top of the clip locks in them.
Sorry the body shop had the new spoiler on for a test fit,could't get a pic of the piece the clips slide into that is attached to the hatch.
Thanks a lot, lookes like I have to find a replacement for the metal insert, the one in my pics is corroded for sure.
I'm interested in the plastic clips, I'll send you a PM.
Engine: 5.0 EFI
I might be able to pull them out of the old one,I' let you know if they come out without damaging them.
Well, I finally decided to change the existing, cracked and bad looking wrap around rear spoiler on my car by a fiberglass replacement, but......
Nobody wants to ship it to Europe, I'm afraid....
I'm still waiting on a shipping quote from Classic Ind.
I'm also waiting on a quote from Spohn.
Hawks doesn't ship outside the USA...
I can't find anything on Ebay either.
As the 3gen. Firebird is hardly sold in Europe, and is now a rather old car, nobody makes anything aftermarket overhere...so I'm totally depending on suppliers from the USA.
Engine: 5.0 EFI
Good Luck.Buy the way Classic is running a sale at this time for a 15% discount and Free shipping,but the free shipping is for the 48 lower states
Spohn doesn't ship outside the USA, they wrote me today...
Are there other suppliers that I might try?
Car: Pontiac Firebird Trans Am GTA
Engine: 5.7L L98
Transmission: Automatic 700R4
Axle/Gears: 2.77 standard
Hello Fire "Dutch" Bird
I have the same problem too!
Do you have a solution already?
Next wednesday it's off to the paintshop to have the wing done, and some minor parking damage as well...
Street Lethal
04-30-2019 12:14 PM
1992rs/ss
16
01-28-2016 09:58 PM
IROCZDAVE (88-L98)
09-02-2015 08:43 AM
