retarded doors
retarded doors
whats the quickest and best way to fix my doors. you have to slam the drivers side door shut and half the time it still doesn't shut all the way.
anybody have any problems opening their doors? i have to use 2 hands and my body weight just to open the damn things
The reason its hard to shut your door is because it has such a tight suction. That is good, no leaks. If Im right you should be able to crack the windows and shut it with ease. I have the same problem, well its not really a problem.
1992 Camaro RS 3.1L
T5 Manual 5 speed
Cold/RAM air intake
Z-28 Exhaust
8.5mm MSD Ignition wires
TB Coolant bypass
Soon to be a 3.8L turbo RS
AIM screen name - Stopsign696
Kills:
95 (****) Probe GT,94 Mustang GT,91 CRX (dont ask me why he raced me),2nd Gen Z28 (350) haha to you V8 guys!,1992 RS 305 TBI (good race),First Gen Integra, Old Escort LX
More to come
1992 Camaro RS 3.1L
T5 Manual 5 speed
Cold/RAM air intake
Z-28 Exhaust
TB Coolant bypass
Kills:
More to come
sounds to me like your hinge pins and bushings need to be replaced, if its anything like my old camaro , the doors are probably sagging, and when you close them they are either contacting the door sill or the bolt the latch hits, try that and adjust the doors as well, should atleast help a lil if nothing else.
87 IROC-z 305 TPI 5spd Borg warner 9-bolt 3.45 posi 4 wheel disc,8.8 Accel wires , bosch platinum +4 plugs,gutted air box,k&n oil filter,synthetic oil 10w30
