Grant GT Wheel....again
Well, I got my steering wheel installed, looks great, horn works...BUT, everytime I turn, the adapter rubs against the steering column...**** like this pisses me off!
Any repair suggestions??
1991 Firebird Formula, 305, TPI, Auto...stock till I get some money!!!
Former owner of an 88 2.8 Firebird....RIP
Car: 86 iroc
You may have the wrong splined adapter or post cover.dont use it until your sure.E-mail grant,they are very helpul.tell them what model and they will tell you what # should be stamped on the hub.
~mike~
1 superclean 86IROC-Z
~mike~
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
is everything aligned?
Mine doesn't rub or anything, no sound comes from my adaptor.
Zepher
'86 Pontiac Trans Am WS6, LG4 305, 5 Speed, CF DF Clutch,
Edelbrock 1406 Carb, Edelbrock Performer RPM 7101 Intake Manifold.
Edelbrock Open Element Air Cleaner: Flowmaster Exhaust, 160* Thermostat,
Grant GT Steering Wheel, MSD HEI Coil, Taylor 8mm Wires, Leather 96 Camaro SS Seats,
Alpine CD+Changer,Alpine V12 Amps, Premier TS-1040C Subs, Polk Audio highs/mids.
Best ET: 14.94@91.67
High Speed Run: 157mph
WS6 Trans Am
Zepher
WS6 Trans Am
Well, a couple of small adjustments and theres no more rubbing...but now I realized another problem...the stupid Ifl. Res. light will never go out....what can i do to stop this??
God ****in damnit!!!!
The thing is rubbing again, so i went to the Grant website and they apparently dont make an adapter for 90-92 firebirds, even thought they told me this one would work at Canadian Tire....it fits right, but it rubs!
On top of all this, the Airbag light is always on and now the horn connection is all ****ed so I have to redo that...this is becoming a real PITA!!
I just put my new Grant GT wheel on yesterday and I've had the same problems. The inflator light has a simple fix-PULL OUT THE BULB! If you have cracked the horn sleeve in the column like I did you'll have to go with the "top A" position with the hub adapter. You will have to trim the black plastic tube that covers the wire and keeps the spring in place. With the hub in the A position it will also keep pressure on the sleeve/spring and maintain contact for the horn. Mine has real tight when I first tried it out and the black cover rubbed on the column. I've loosened the shaft nut slightly a few times and drove the car to work the wheel and it's almost back to normal. If all else fails I'll pull it back off and trim/grind the back edge of the cover. I'm using the 14" Formula GT in black.
Mongoose-NCTGA-1990 Pontiac Formula/305 TBI-700R4 with Edelbrock Performer TBI intake,TES headers,and STB,K&N,MSD-6AL,Holley laser shot coil,Accel Extreme 9000 wires,Jet Stage 2 chip,TCI shift kit with corvette servo,Richmond 3.73 gear with Auburn 3 series posi,no cat,SLP 3" cat back,Eibach sportline springs,Energy Suspension poly throughout,Lakewood LCA and adjustable panhard bar package,SSM subframe connectors,IROC wonder bar,Tokico 5 way adjustable struts and shocks,Autometer electric fuel pressure gauge,Alpine,JL Audio,MB Quart,92 GTA taillights,92 GTA aero wing and hatch,Steve Spohn LCA relocater kit,MacEwen White face gauges,84 T/A cold air induction air cleaner.
Z28 Boy
Aftermarket Product Review
20
01-09-2001 08:47 PM
