Painting the whole thing cost
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: A Camaro
Engine: Weak
Transmission: Weaker
How much would it cost for a shop to paint a full camaro a different color than it already is? This includes door jambs, engine compartment, everywhere? Let's say a nice shiny yellow. Best guesses are cool, thanks, Tony
You doing the prep work or them? Does it need any body work such as dings or deep scratches. It could cost up to $4000, if you went all out with details like diff. color ground fx or racing stips.
Mike Kenny
Current: 1991 RS 305 TBI
Past: 1990 RS 305 TBI (A woman forgot what red lights are for)
Current: mostly stock - newer 305 w/ 12,000 on it
Eclipse speakers all around w/ 10" tube powered by a Alpine V12 in back
K&N filter w/XStream flow lid - It is sweet!!
Future: 2" Cowl hood
Mike Kenny
It all depends on the shape of your car now. Any rust? Things that would affect price are whether they have to strip old paint or not, kind of paint (urethane,base/clear etc..) .
You can get a factory quality paint job for around $1800-$2000. There is usually an extra cost for a color change.
Oh yea, a good paint shop will remove all your bumpers and GFX also. That is the proper way to do it. I would say the proper quote would be more like in the $3000 range.
91 Formula
305 TPI 5speed
1LE/G92/WS6
Custom cold air intake w/K&N, SLP airfoil, ported plenum, TB coolant bypass,Crane AFPR (47psi),94 octane,Crane Extruded Alum. 1.6 full roller rockers, Timing set from 4*BTDC to 10*BTDC,MSD coil,MSD6AL, Holley 9mm Annihilator Laser shot 50 wires, Ac Delco cap,rotor and plugs, Bosch O2sensor, SLP 1 5/8 headers,SLP catback,3:73s,JET 195* fan switch, Macewen white face gauges, Autometer gauges, Zoom hi-performance clutch.
Street legal with stock throttle body, runners,intake manifold,cam, and heads. Coming next..9# Procharger!
91 Formula
305 TPI 5speed
1LE/G92/WS6
Just gone one, it ran me $3333, but I also got over $1000 in new parts and stripped/dismantled it and reassembled it myself. The more you can do yourself the more you'll save, parts will cost the same, but the shop's time is a lot more costly than yours is, plus you get to know the car a little better
ambainb
04-25-2016 09:21 PM
